258 w/Carter BBD running rough - JeepForum.com
post #1 of 6 Old 06-28-2013, 02:15 PM Thread Starter
zx150
I'd got an '84 258 with the Carter BBD (High Altitude). Most if not all of the computer stuff has been axed or bypassed by a DS "mechanic" I had replace the valve cover 2 years ago but it's always started and run 100% fine regardless.
Two days ago it started to run rough at idle and stall every time I come to a stop. I thought I had bad gas so I added carb cleaner to the tank, new fuel, changed the filter and cleaned out the carb with an entire can of carb cleaner but that only seemed to help just a little bit.
With the way it's running is this one of the failure modes of the Carter BBD? What can I do to get it running good again?
This is on an '84 AMC Eagle but it's the same system as the CJ/YJ/SJ.
Thanks!
zx150 is offline
post #2 of 6 Old 06-29-2013, 09:30 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here you go. Common problem and easy fix.
http://www.jeeptech.com/engine/carter.html
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 6 Old 06-30-2013, 10:49 AM Thread Starter
zx150
Drilled out the idle tubes and flossed them out. Runs great now.
zx150 is offline
post #4 of 6 Old 06-30-2013, 03:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I had a feeling. pretty easy, eh?
post #5 of 6 Old 06-30-2013, 04:37 PM Thread Starter
zx150
Totally. If you're careful you can even do it without removing the entire carb but I did just to be safe.
I've been driving this one for 4 years now and it's the first issue I've ever had with the BBD.
zx150 is offline
post #6 of 6 Old 06-30-2013, 04:47 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I can't remember all of them we did on the 258s at the dealership back in the day. Pull the top off, lift out the tube assembly, drill, flush out, go back together.
