258 vs 258? - JeepForum.com
post #1 of 2 Old 03-22-2014, 11:25 AM Thread Starter
syphonation
258 vs 258?
hey guys, i have a quick question. i recently bought an 82 scrambler, and it came with an extra motor. the seller knew nothing about whether it ran or not, and i haven't had time to really investigate. however, the motor that's currently installed is ticking pretty bad. i figure either a valve sticking or a rocker arm.
upon closer inspection, the "extra" motor appears to be the original to the scrambler, as the motor that's in it is older. i'm just wondering if there's a way to pinpoint what year this motor was built - or were the 258's back then all interchangable in terms of internal parts?
i'm hoping i can use the donor motor for parts if i need them, but in the instance it's no good and i have to buy something, i'm going to be in a bind not knowing what year cj my motor came from.
syphonation is offline
post #2 of 2 Old 03-23-2014, 01:06 PM
strvger01
1966 CJ5
engine casting number on the block is one way you can find out. as far as i know, internals should be interchangeable, unless one of them has had some work done inside, ie: rebuilt and bored out, non-stock cam, etc.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
