258 valve cover on 4.0 head ?????? - JeepForum.com
post #1 of 4 Old 07-04-2009, 11:54 AM Thread Starter
Bruner3
I just saw on ebay some guy claiming a 258 and 4.0 valve cover are interchangeable..... Anyone know if this is true ? Doing the 4.0 head swap thing and this would save me a little $ and time.....
Bruner3 is offline
post #2 of 4 Old 07-05-2009, 06:06 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
won't work,sorry.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #3 of 4 Old 07-24-2009, 01:43 AM
th3t1nm4n
It won't work without modification. If you want to see why just compare the gaskets.
th3t1nm4n is offline
post #4 of 4 Old 07-27-2009, 09:07 AM
Happy Joe
Just use the stock cast 4.0 valve cover when you switch to the 4.0 head... they are cheap and widely available in scrap yards (I got one free with a head, I just asked the guy at the counter and he threw it in for nothing).
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
4.2L Valve cover on 4.0L? SierraDave Engines & Drivetrain 3 06-30-2008 07:04 PM
2.5L Valve head cover leak erickpl Engines & Drivetrain 18 02-22-2005 07:38 PM
Valve Cover my1stjeep Engines & Drivetrain 3 06-22-2003 10:04 PM
valve cover ? rustyCJ Engines & Drivetrain 6 10-25-2002 11:26 AM
What valve cover do I have? Buzzard Engines & Drivetrain 1 11-25-2001 02:24 PM
