258 problems under full load - JeepForum.com
post #1 of 14 Old 05-14-2012, 05:20 PM Thread Starter
Randonexplosion
Randonexplosion's Avatar
Hey guys, I'm having problems with my 258. My girlfriend first noticed the problem while taking the Jeep to work on the highway. It will not do over 50-55. Driving around town it runs great (under partial throttle) and it revs without a hiccup while parked. The problem occurs when the rpms are around 2k and you give it heavy throttle while driving. It sounds like it is reving like crazy. I've never heard the motor sound like that before. Does anyone have any suggestions on what to check? i'm thinking it isn't getting enough spark/juice under load. Thanks for any help
Randonexplosion is offline
post #2 of 14 Old 05-14-2012, 05:53 PM Thread Starter
Randonexplosion
A couple of other notes, my plugs look like it is burning a little rich. Also the fuel pump and filter arent very old. I dont put many miles on the Jeep.
post #3 of 14 Old 05-15-2012, 12:00 PM Thread Starter
Randonexplosion
Bump
post #4 of 14 Old 05-15-2012, 10:40 PM
jnicewan
You may be right, its hard to say without being there and looking at it. Look at the spark and see if its weak/strong, you should see a nice pinkish/purple spark and it should be able to jump around a half inch gap or so. Your problem sounds like it might be a fuel concern or weak ignition system but sounds like you have a good fuel supply. Maybe check the coil and spark quality, wires, cap and rotor and ignition timing.
Check the obvious stuff too like air filter, and throttle linkage to see if you are getting WOT, make sure the choke plate is not sticking closed. Also its possible that the fuel filter could be stopped up from debris in the tank or dirty/bad fuel.
jnicewan is offline
post #5 of 14 Old 05-17-2012, 09:14 AM Thread Starter
Randonexplosion
Thanks for the suggestions. Everything with the carb seems fine, the choke plate is functioning normally. I will grab a fuel filter and switch that out. I played with the timing but that didn't make a difference. What is the best way to check the coil and spark quality? I wish I could explain it better. When I dump the throttle it sounds like I have a V8! Part of that could be the leak between the manifold and the down pipe though.
post #6 of 14 Old 05-17-2012, 06:56 PM
cruiser54
1990 MJ Comanche
Try this vacuum test.
CRUISER’S VACUUM TEST FOR EXHAUST RESTRICTION
Your vacuum gauge should come with an instruction booklet outlining the procedure. Hook the vacuum gauge up to a source on the intake manifold. Start the engine and note the vacuum reading. Usually 17 to 21 inches of vacuum. Throttle the engine up to 2,000 to 2,500 RPM for 20 seconds or so and the vacuum reading should stabilize to the same reading you got at idle. Let the throttle snap shut. The vacuum reading should shoot up about 5 inches of vacuum higher for a second and then come quickly down to the original reading. If the vacuum reading stays high and comes down slowly with jerky needle movements, you have an exhaust restriction.
cruiser54 is offline
post #7 of 14 Old 05-18-2012, 06:59 AM
james04si
james04si's Avatar
1977 CJ5
When going at 50 and you press the gas does it do more than just sound like its revving? If it is actually revving it could be your clutch slipping.
james04si is offline
post #8 of 14 Old 05-18-2012, 12:14 PM Thread Starter
Randonexplosion
No its not actually revving. The motor just sounds like a beast at WOT
post #9 of 14 Old 05-18-2012, 12:16 PM Thread Starter
Randonexplosion
I'm gonna go pick up a vacuum guage this afternoon. I am leaning towards exhaust restriction too. I'll let you know what I find!
post #10 of 14 Old 05-19-2012, 09:35 PM Thread Starter
Randonexplosion
It was the cat. I have an exhaust leak upstream from there that was causing the brutal sound.
post #11 of 14 Old 05-19-2012, 09:50 PM
cruiser54
1990 MJ Comanche
Did you find the solution using the vacuum gauge?
post #12 of 14 Old 05-19-2012, 10:01 PM Thread Starter
Randonexplosion
No I didn't. Either I didn't follow the instructions well or there wasn't enough of a blockage unless it was under load. I just got curious and tapped it with a hammer and hear the loose honeycomb bouncing around.
post #13 of 14 Old 05-19-2012, 10:41 PM
cruiser54
1990 MJ Comanche
Lucky dog.........
Glad to hear you found it.
post #14 of 14 Old 05-19-2012, 10:52 PM Thread Starter
Randonexplosion
Thanks man. It was a lucky catch. Me and my friends were pretty puzzled.
Load D vs. E Zoolander Tires & Wheels 14 04-01-2010 01:35 PM
Major Full drivetrain problems 04Xman Engines & Drivetrain 0 01-17-2010 07:10 PM
Is any load range ok? StevieO40oz Tires & Wheels 1 03-30-2009 12:07 AM
Load C Vs. Standard Load ntaousakis Tires & Wheels 6 01-11-2008 09:55 AM
E-Load vs. D-Load dallasjetfan Tires & Wheels 2 10-12-2007 12:08 PM
