258 Main Bearing Trouble - JeepForum.com
post #1 of 2 Old 08-05-2012, 08:14 PM Thread Starter
matthewmorton
1981 CJ7
Alright,
I decided to replace the main bearing set in my 81 258 while I had the engine out and the oilpan off. My problem is this, I have the engine with combo standard and .001 bearings. I cannot find the .001 bearings anywhere! What have you guys done in the past to fix this problem?
Thanks.
matthewmorton is offline
post #2 of 2 Old 08-06-2012, 08:06 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Two options come to mind given you can't find the proper bearing size.
If the crank is .001 under (bearing .001 thicker then stock), you may be able to use a standard set of bearings and shim the cap bearing with paper. Newspaper is app .003 thick, while an electronic receipt is about .002. Cut the paper about 3/4 the length of the bearing half and place it under the cap bearing, being sure it doesn't get under the lock tang. Plasticgage the bearing to insure you have enough clearance. I know it sounds like THE most redneck thing ever, but I have seen it done a couple of times and it worked (Jeeze, I flinch even mentioning it here).
The other (better) option is to replace the crank with a .010/.010 grind. This will standardize your mains and rods. this fix will, however, be a bit more entailed.
Remember to check the clearances on the new crank as well.
jeepdaddy2000 is offline
.001 , 258 , bearing , main , standard
HELP! Cant get rear main bearing cap out... JeepinJordan Engines & Drivetrain 2 04-14-2012 11:36 AM
main bearing install write up ? mark12010 Engines & Drivetrain 6 10-01-2008 06:08 AM
Main Bearing condition? 258 whittlecj Engines & Drivetrain 0 09-30-2008 09:07 PM
oil leak & rear main bearing elfman69 Engines & Drivetrain 3 06-06-2007 06:24 AM
worn out main thrust bearing amcpapa Engines & Drivetrain 3 05-07-2002 05:28 PM
