232 vs 258 Mods and Identification - JeepForum.com
post #1 of 2 Old 04-17-2004, 12:02 AM Thread Starter
Orange Juice
Asked this ? in the CJ forum a few days ago, but nobody answered. Maybe this would be a better place for it.
Recently bought 74 CJ5 and was told it has a 232. Considering the age of it, I don't know if the engine is the original or not so looking at the VIN probably wouldn't matter. Is there an easy way of telling the difference between the 232 and 258?
As far as performance mods, from what I understand, the only difference in 232 and 258 is that the 258 has a longer stroke. I would assume the same parts work on each engine, but will the same mods work? I want to upgrade carb/intake, but also started reading about the 4.0 head conversion and am also considering that too.
I have been reading thru the many posts here, but haven't seen anything posted about which mods will/will not work on both engines. Thanks
Orange Juice is offline
post #2 of 2 Old 04-18-2004, 12:15 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
can't help with the mods, but to tell the two apart, you need to look at the casting numbers on the block. one starts with an "A" and the other with an "E" if i remember right. was looking at a 76 CJ-5 but it was sold before i could get it and now for the life of me i can't remember which is which. I do remember that i found the answer on Pirate's board. They're having tech difficulties now or i would look it up for you. I believe the A was the 258. maybe someone with a 258 can look for you and see. I think the numbers were on the passenger side of the block, just below the head but i'm not 100% sure of that. HTH
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
Part Identification Roadymi Engines & Drivetrain 3 10-26-2009 08:46 PM
Terminal Identification JohndKc Audio, CB & Ham Radios, GPS, & Electrical 4 10-22-2009 08:57 PM
Need help with engine identification Lunchbox2011 General Jeep & Off-Road Equipment 1 12-13-2008 02:10 PM
Identification Help Powerplay Tires & Wheels 2 11-20-2008 05:00 AM
Ford 8.8 Identification Tag lukera Engines & Drivetrain 3 10-13-2006 08:36 AM
