231 transfercase stuck in 2wd - JeepForum.com
post #1 of 2 Old 10-23-2011, 09:24 AM Thread Starter
supniceyeah
nothings easy : )
bought a 231 to replace my 249. after putting it in found out fill plug was stripped, guy never told me this. awesome.
Now got it filled with fluid and all hooked up and can't shift it out of 2wd. not a linkage problem cause when i throw a wrench on the case where the tab hooks up, it won't move. have the tranny in neutral, tried rolling the jeep a foot or two while under there with a wrench trying to shift it, nothing
so i'm assuming something inside is broken or should i try something else? it was my dumb fault to trust the guy saying it worked fine, i didn't know what to look for in buying a transfercase, i guess i'll know now
99 WJ,4.0, stock
93 ZJ,4.0, 5.5", 33x12.5 mts
96 ZJ,4.0, stock: deceased
87 YJ,4.2, stock: sold
supniceyeah is offline
post #2 of 2 Old 10-24-2011, 02:50 PM Thread Starter
supniceyeah
in case anyone has this problem after a swap, you can't use the shift indicator plug from the 249 on 231. maybe this is common knowledge, wasn't to me though ; )
pulled the plug and can shift it no problem, no i gotta find something to fill that hole
99 WJ,4.0, stock
241c transfercase divco13 Engines & Drivetrain 3 03-14-2011 04:45 PM
Transfercase issue Bluejeep88 Engines & Drivetrain 1 01-31-2011 10:14 PM
Transfercase will not adjust.. wow682 General Jeep & Off-Road Equipment 0 06-30-2009 11:23 AM
transfercase ? please help wrangler 06 Engines & Drivetrain 1 11-08-2006 03:13 PM
transfercase yokes rustyCJ General Jeep & Off-Road Equipment 2 06-23-2003 11:21 AM
