2011 jeep wrangler problems - JeepForum.com
post #1 of 11 Old 06-12-2011, 02:35 PM Thread Starter
kingtab84
Hey all. So just a week ago I got a 2011 jeep unlimited sport. Already the throw out bearing needed to be replaced because of a whining sound from the clutch. Brought it in yesterday(saturday) morning and they had it all fixed up by saturday night - covered under warranty. I then today(Sunday) tried shifting into 4WD hi - I was stopped in a fast food drive through and just wanted to test everything out... well, as I pulled, the stick just moved freely, and didn't move out of 2W hi. The 4wd stick just moves with slack and doesn't change the 2wd/4wd. My jeep has under 1k miles on it, and already these two problems. Anyone know the cause of this, and will it be covered under warranty also? I would expect it has to be, just want opinions of what it is.
thanks!
kingtab84 is offline
post #2 of 11 Old 06-12-2011, 04:42 PM
srmitchell
Man... Don't do that again. In the drive through?! Jeeps sometimes need to be rolling for a smooth t case shift.
It may need to be adjusted, but sometimes they just need to be worn in.
My xj had a very sticky t case lever when I bought it. The previous owner never used 4wd, and now that I have it, it sticks much less.
I work on Mopars
srmitchell is offline
post #3 of 11 Old 06-12-2011, 04:50 PM
HurricaneRZA
Welcome to the Jeep family! Please, for the love of all things Jeep, do not shift into 4-Anything on pavement until you've become accustomed to it. If you want to "test everything out" try it out on a dirt road. Shift it into 4hi and SLOWLY roll a bit forward. It should click into 4wd as you do.
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #4 of 11 Old 06-12-2011, 05:02 PM Thread Starter
kingtab84
ok thanks for the tips guys! will this be covered under warranty? and if not, what would cost to fix be?
post #5 of 11 Old 06-12-2011, 05:37 PM
HurricaneRZA
Like it was stated before, its probably not even broken. If i'm not moving I can shift between 2hi/4hi all day and nothing will "click" in. On the off chance that it is faulty, yeah, it would most likely be under warranty.
post #6 of 11 Old 06-12-2011, 05:51 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
You sir, need to read the owners manual that is residing in your glovebox.
If by chance the lever is doing nothing at all, then it is not hooked up under the rig. In that case, it is most assuredly under warranty. There may be a chance that the "technician" didn't hook the rod back up to the transfer case when he replaced the tranny etc.
Poor job on his part, but by far the end of the world.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #7 of 11 Old 06-12-2011, 05:57 PM Thread Starter
kingtab84
thanks for your replies, makes me feel calm. I was really worried when it happened but after research it seems this is an easy to fix problem. hopefully warrantry will cover it and the part will be in stock.
post #8 of 11 Old 06-13-2011, 04:00 AM
tjjeepwrench978
1997 XJ Cherokee
i had a 07 sahara bought it with 200 miles on it death wobbled at 70 on the highway dealar and mopar wouldnt do a thing for me
tjjeepwrench978 is offline
post #9 of 11 Old 06-13-2011, 10:03 AM
srmitchell
You should also be happy that jeeps are generally very durable, and most parts are inexpensive to fix. (Compared to most 2011 vehicles)
I work on Mopars
post #10 of 11 Old 06-13-2011, 04:22 PM
wheelin
the tech probally just left the transfer case shifter unhooked.
95 yj
wheelin is offline
post #11 of 11 Old 06-14-2011, 06:10 AM
leftlanetruckin
XJ on 37's
Originally Posted by wheelin View Post
the parts swapper probally just left the transfer case shifter unhooked.
There, fixed it for you
Martin
2011 Jeep Wrangler Sport scooter2011 Tires & Wheels 5 03-27-2012 10:15 PM
2011 Wrangler - New Wheels / Tires - Help! rmlk77 Tires & Wheels 0 05-31-2011 10:46 PM
2011 Jeep Wrangler AmnWatkins General Jeep & Off-Road Equipment 0 12-13-2010 07:34 PM
wrangler duratracs for 2011 jeep wranger sport 4xar Tires & Wheels 1 11-16-2010 05:39 PM
jeep 90 wrangler lift problems smakki69 Tires & Wheels 2 03-29-2007 11:02 AM
