-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   2010 Grand Cherokee brake issue (http://www.jeepforum.com/forum/f19/2010-grand-cherokee-brake-issue-1541961/)
edobrowansky 06-27-2013 09:17 AM
Good Morning.
Yesterday I installed new brakes on my '10 Grand Cherokee. I purchased the full rotors/pads front and rear Mopar kits from a local dealer. Other than dealing with the springs for the rear emergency brake shoes, things went fairly smoothly. However, I now have a major issue.
When braking while moving at highway speeds, the brakes feel nice and smooth, no pulling, etc.... However, when I come to a complete stop, or a rolling stop at around 5-10mph, I hear a clunking sound, like a "thump thump thump" . It seems to get louder the slower I go. And the harder I press the brake pedal. However, I can drive in reverse and never hear the sound. Only in a forward direction. So I pulled the wheels, looked over the brakes once again, and do not see anything that looks out of the ordinary.
Warped rotor? Or a bad pad? Otherwise, the breaking seems too smooth to be a bad rotor. I've experienced bad rotors in the past, and this does not feel anything like it. Maybe a pad is not sitting right in the caliper on the inner side of the rotor?
Is there a remote possibility it could be the rear brakes? Maybe something with the parking/emergency brake is not quite right? I did have one minor issue with the rear driver side parking brake engaging lever where the cable attaches from the rear. The lever assembly that sits between the upper and lower shoes and on the opposite side of the adjuster, where the cable hooks onto, popped off during the disassembly process. I think I put it back in correctly, but it was a pita. Is there some sort of diagram on the web that shows the rear brake assembly and the correct installation of the parking brake hardware?
Thanks
Eric
My next step I would think
laybackman 06-27-2013 03:38 PM
I just went through a similar issue with my '01 WJ. I would get this 'noise and low brakes going forward and stopping. BUT the brakes worked fine in reverse. I found one brake pad that was detached from its backing plate. When moving forward it would drop out of place but in reverse it would slide back into its proper position.
edobrowansky 06-29-2013 10:31 AM
Laybackman,
Was that a repeating click sound as you came to a stop, or just one click when the pad settled into the forward position?
I am getting a repetitive click sound, almost like one click per tire revolution. Yesterday I pulled all four wheels, inspected the pads, rotors, and calipers. About the only thing I can see is that the one rear passenger side inner pad - the outside end "ears" that sit on the snap-on clips of the caliper assembly - it looks like there is about a 1/16-1/8" gap where the pad could move up or down, whereas all the other pads look to be quite snug. Could that little amount of play be allowing the pad to move? If so, I would think the click would only be heard once in either forward or reverse from inertia pushing it one way or another.
The only thing I can think of at this point is that maybe I have a rotor that is not right, and there is a high spot that is causing the caliper or pads to move every rotation.
Eric
laybackman 06-29-2013 01:22 PM
Originally Posted by edobrowansky (Post 15621185)
Laybackman,
Eric
Repetitive like a machinegun for my friends rear brake shoe issue.
My front brake problem made no noise that I could hear but the brakes dropped real low going forward but worked fine when backing up.
IF you have one click per rotation I would check the low brake pad thingy that scrapes when your pads get thin maybe it needs some adjustment OR you have a cracked pad or rotor.
Once you hit your brakes no pad can move UNLESS the caliper isn't closing enough. Then you might get some pull to the opposite side of that caliper.
The time now is 04:31 AM.
