2005 liberty - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 2005 liberty
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 04-14-2012, 01:23 PM   #1
dansmith
My liberty after running for awhile in heavy traffic or slow moving traffic. The engine seems to get hot,if you stop somewhere and shut down the engine for a short time,it will not restart. It needs to cool of before it will start,sometimes almost a hour. I have checked the coolant levels and thermostat and water pump not leaking and operate properly. Any other ideas,please help.
dansmith is offline   Reply With Quote Quick reply to this message
Unread 04-14-2012, 01:30 PM   #2
benmar2000
Ok.. First off, you need to learn how to write better sentence structure. But if i am reading it correctly, your KJ will shut down after it has run for a while due to overheating.
First, check your coolant level.
Second, check to make sure your thermostat is working properly. It might be shut closed and causing your engine to over heat.
Third, check your water pump. Make sure there aren't any leaks coming from it. Like from the weep hole indicating that the water pump has gone bad and it isn't circulating water like it should.
Forth, check your fan. Is your fan mechanical or electric. See if the fan is turning if it is mechanical while the engine is running. If it is electrical, make sure it kicks on when the engine gets up to temp.
Fifth, check your radiator for mud. But this only applies if you have taken your KJ off road and been mudding.
Also, fill out your profile more. The 2005 KJ came with 2 different engines, the 2.8L diesel, and the 3.7L gas..
benmar2000 is offline   Reply With Quote Quick reply to this message
