2005 Grand Cherokee won't start - JeepForum.com
post #1 of 12 Old 07-21-2010, 05:56 PM Thread Starter
Rhenne0
2005 XJ Cherokee
I have a 2005 Grand Cherokee, 5.7 that won’t start. The battery has tested good, wire leads has been cleaned and checked for tightness and all lights, radio, horn, etc. work fine. I hear one lick when I turn the key, which sounds like it is coming from a relay switch near the battery. Have not had any problems with the starter in the past and no clicking sound that you would normally hear when the starter goes out. I have also tried turning the key and shift to different gears, but still won’t start
Any advice you can give me would be appreciated.
Rhenne0 is offline
post #2 of 12 Old 07-21-2010, 06:15 PM
BulldogTJ98
Hit the sh*t out of the starter with a hammer and try it.
My Build Thread:
'98 TJ 4.0L, AX-15 5spd, NP231, RE 4.5 rear, 3"&.75" BB front, JKS discos, 33x12.50 KM2s on Rock Crawlers, 3.73s, Dana30 front, Dana 44 rear, JB Conversions SS SYE, JKS HD Tierod, Warn 8274 Winch, Front Stinger and Rear stinger w/ tire carrier, Rokmen Corners, Aluminum Radiator, LED tailights, Rock Lights, KCs, K&N airfilter, Optima Redtop, Cobra CB and a Sony soundbar
BulldogTJ98 is offline
post #3 of 12 Old 07-21-2010, 06:34 PM
ajmorell
ajmorell's Avatar
Sounds like the starter to me.
ajmorell is offline
post #4 of 12 Old 07-21-2010, 07:13 PM
BulldogTJ98
Have somebody check your batterie's cranking amps of the starter ends up being good. You can have 12+ volts and no amps and its like having a dead battery. Good luck
My Build Thread:
post #5 of 12 Old 08-20-2010, 10:21 PM
cad70
Have you figured it out yet? I have the same thing happening on my 2005 4.7. It started fine after an overnight wait then did it again tonight after working for two days. I swapped the relay but still no luck.
cad70 is offline
post #6 of 12 Old 02-06-2011, 09:36 AM
Slartibartfast
2007 WK
had what sounds like the same thing happen to my 2007. all electrics OK but turning the key to the "start" position, nothing happened. liked most to do it during short trips, pickup son from school, goto the supermarket for milk, etc. they replaced the battery, tested the starter 9 ways to Sunday. ultimately a creative dealer replaced my key because the sim card in the fob was not authenticating itself with the Jeep, so the Jeep would disable the starter. the computer recorded what he termed as a "key fault" code. might be fooie, might not, either way not a problem since.
Slartibartfast is offline
post #7 of 12 Old 02-25-2012, 02:07 PM
nduro
Curious if there is any follow-up on this.
I have the same vehicle, 2005 Grand Cherokee with the 5.7 Hemi.
Drove a lot yesterday and had no problems. This afternoon I go out and the key fob will not unlock the doors. It attempts to but the door locks only seem to move half way.
After getting in I put the key in and turn it and all I get is a spinning/clicking sound coming from the engine compartment.
The strange thing is that all of the dash lights come on, the power seats work and move. However, the overhead lights do NOT come on and I also noticed the fuel gauge was not moving either. It seems like some electrics are working and some are not.
The dash gave me the 'check electric brakes' and 'check 4wd system' errors.
We did get some decent rain last night and a lot of wind and it was outside all night, but I can't imagine that is related.
It's an '05 with 72,000 miles on it.
I seem to be having lots of problems with this thing. Been dealing with front-end noises that the dealer can't find as well.
Anyone want to buy a nice '05 that may or may not start?
Would love to hear any suggestions anyone might have.
Thanks.
nduro is offline
post #8 of 12 Old 02-25-2012, 04:51 PM
nduro
Follow-up on mine. My problem turned out to be the battery. Managed to jump it and get it to auto zone where I had a new battery put in.
However, now there is a new problem: the bright lights are on all the time now. Even when the truck is turned off. The horn just starts to randomly beep and won't stop. The directional lights no longer function.
All of this just from replacing the battery?
Am I missing something? Help! Please!
nduro is offline
post #9 of 12 Old 02-26-2012, 09:58 AM
nduro
Another follow-up for those who stumble across this thread from a search.
After having the issues I had yesterday after installing the new battery I unhooked the negative terminal and let it set overnight.
Hooked everything back up this morning and all seems fine. My guess is there was something in there still holding a charge that was causing problems. I had read elsewhere that leaving it unhook for 10 minutes was plenty to do the job. I didn't need to go anywhere so I just left it overnight.
Might be helpful for others who run in to a similar problem.
nduro is offline
post #10 of 12 Old 03-03-2012, 09:11 AM
Slartibartfast
2007 WK
2007 WK Laredo, the vehicle I decided would benchmark my working hard & coming into my own.
after intermittent starting issues (4 weeks, then 2 weeks, then 3 days, then next day sort of thing) i heard from so many WK owners, i went to (3) different Jeep Dealers, (2) Jeep Factory Indecent reports with the same issue, and finally a private garage. After a screaming match with my Jeep Case handler the best course of action was going to be to trade in my Jeep and buy a Subaru.
While pre-reading my future vehicle's owner's manual (roll your eyes, call me Geek) they have an excellent trouble shooting guide, one section dedicated to intermittent starting issues that deal with an excess of metal (key-chains, fobs, other keys) touching the starting ring around the ignition creating a "key fault". it made sense, the Dealers wouldn't have an issue because i only have them the Jeep fob. further, it would be fine for a couple of weeks after because they would disconnect the battery overnight for diagnostics. turns out, i had an issue because i use (4) split rings, a nylon strap and a big caribeaner.
(6)months with just the key, then (6)months with a non metallic key-ring (
), i can say it's been a full year without an indecent. I get the keep my Jeep.
post #11 of 12 Old 02-27-2014, 11:42 PM
kevin1983
05 jeep grand cherokee 4.7
if anyone has problem with jeep not starting just turning over than try putting new tps mine went out and give me all kinds of problums I almost put new computer cus all kinds **** was on moter light track controle desabaled brakes light on running like **** would not shift out of first gear all crazy all because of tps so hope this helps others
kevin1983 is offline
post #12 of 12 Old 01-19-2015, 06:22 AM
rockbox
2005 WK
I do have the same issue, as I will wake up my HEMI in the morning with no any issues till it gets wormed up and drive for 30 mints to work, so if I tried starting my jeep after this period of driving I will have the below symptoms:
- ECT gage will fall down.
- Security light will start flashing.
- Engine will not crank.
-Transmission Over temperature message will be displayed.
- Service electronic break system.
-service 4WD system.
If I kept my jeep to cold own for a while for like 45 minute it would start normally back with no issues.
However if I did the below:
Remove the battery and wait for a few minutes or removed the PCM fuse and returned it back I will get the car started ok Or/and I might get it started with the below symptoms:
-Gearbox in limp mode.
- Gearbox will shift pretty harsh as if it is in the overheat shifting schedule.
- Gearbox will shift super softly and lots of clutch slippage.
On the other hand I have searched for this issue and found out that the connectors on the PCM are made of plastic and by time it gets expanded and with the excess heat in the engine bay the PCM pins and the connectors will have a separation, to solve this issue I have had to find a solution for something that will keep the connectors pushed in the PCM so I used a tie rap to solve it and it did solve the issue and made the jeep run more responsive, Moreover you need to make sure the gearbox connectors are just fine and cleaned.
I totally agree with you opinion gents that a tie rap is not a solution however I would love to see a creative ideas,
rockbox is offline
no start , will not crank
Where can I get 20" for my 2005 Grand Cherokee? Astro Tires & Wheels 5 04-17-2012 10:08 PM
2005+ Cherokee guys with remote start. gsxr150 Audio, CB & Ham Radios, GPS, & Electrical 3 11-04-2007 06:56 PM
2005 Grand Cherokee & Tires hack05jeep Tires & Wheels 2 05-23-2006 04:01 PM
2005 Grand Cherokee VSS speed wire 05GrandCherokee Audio, CB & Ham Radios, GPS, & Electrical 0 02-26-2006 01:01 PM
Question about stock H/U on 2005 Grand Cherokee crowfan Audio, CB & Ham Radios, GPS, & Electrical 9 07-26-2005 12:26 PM
