-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   2004 jeep liberty running rough help (http://www.jeepforum.com/forum/f19/2004-jeep-liberty-running-rough-help-1066711/)
blackcloud 07-10-2010 12:46 PM
I have a 2004 jeep liberty on a trip out of town today the check engine light came on and started flashing. It is really running rough going down the road. The owners manual said possible problem with my catalytic converter. My question will it hurt to drive it? I will be on the interstate on the trip back home but it is about 300 miles. Thanks for any help.
blackcloud 07-10-2010 03:59 PM
More info I went to auto zone and they said it was the mass flow sensor. Of course they donít stock one. After calling a few auto parts stores none of them stock them and some told me they can't get it. I purchased some cleaner and it didn't help the problem. Thanks for any help.
JBD 07-11-2010 01:58 PM
disconnect the battery for a few mins. and see if that clears the codes and runs better.
RubiconBlack 07-12-2010 07:18 PM
Ok umm the libertys don't have a Mass Air Flow sensor. They have a Manifold Absolute Pressure sensor. Also if the Check Engine Light is flashing, that means it can and will cause damage to the Cats. Do you have the Code number they pulled? That would help. I have seen broken valve springs and carbon on the valves causing running issues also many crankshaft postions sensors. Get the code number and post it. We can get you the help you need.
RubiconBlack 07-12-2010 07:19 PM
PS don't drive it. Cats are not cheap!
blackcloud 07-13-2010 02:16 PM
I went back and ask if it was ok to drive. Auto Zone said yes it would just burn more gas. After I disconnected the battery cables it cleared the codes. I drove it home and took it to the mechanic yesterday. Well I wish I would have read your post before I drove it both catalytic converters need to be replaced to start with and you are right they are not cheap. Before I took it to my machanic called the dealership and they told me there was no mass flow sensor.
RubiconBlack 07-13-2010 06:25 PM
Call that AutoZone back and talk to a manager! The person you spoke to shouldn't be working there if he/or she does not know what they are talking about. And they (in my mind) owe you a Catalytic Converter! Its one piece system. I work at a Jeep dealership and I know most of the in's and out's of chrysler vehicles. Sorry I wasn't faster in responding.
tjkj2002 07-13-2010 06:54 PM
How many miles on your KJ?
The cats have a mandatory 8 year/80,000mile warranty on those cats.As long as they are not damaged via offroading or a accident they must replace them for free at a dealership.
blackcloud 07-13-2010 07:26 PM
thanks but i have 150k on it.
GGibson 07-14-2010 04:33 PM
I work on these things all the time and they are notorious for head problems....You need to take it to a shop and make sure that the motor did not completely sludge up....Like RubiconBlack had said they have a lot of carbon build up problems and it will make the valves stick and cause the rockers to pop out...They also like to sludge like my first comment and it will also cause the same thing and the only real fix is to replace the engine when that happens...but they heads can be fixed if the oil system is ok.
JaysonD 08-23-2014 01:30 PM
I'm having the exact jsame problem with my 04 jeep liberty as BlackCloud sorry to open a dead thread.
Took it to AutoZone and here are my error codes
P0420
P0300
P2314
P2308
P2302
I just replaced the coils and spark plugs still running rough
The time now is 11:50 PM.
