2003 WJ 4.0 CEL code P0206 - JeepForum.com
post #1 of 3 Old 08-13-2012, 12:25 AM Thread Starter
pushinacoach
Need some Jeep wisdom here. Several days ago the engine began to run roughly and the check engine light came on. I have an Autel Diagnostic Tool and pulled a P0206 - Fuel Injector #6 cyl code. I replaced all the injectors with 4 hole Bosch injectors and replaced all the spark plugs. Now the issue seems to be intermittent rather than constant. It will idle smoothly and run great and then without warning run rough and "miss". I get the same code when I scan the system.
BTW - I had a similar issue about 8 months ago and changed the coil pack and plugs and released the pressure in the fuel rail. No more problems at all until last week. Nothing has changed with the JGC. Stumped. Any thoughts? Thanks.
pushinacoach is offline
post #2 of 3 Old 08-13-2012, 01:25 AM
jnicewan
Check the connector at cyl #6 injector. I had one in the past that had a loose pin in the connector. Also look at the wiring real good and make sure its not rubbing somewhere and check to see if the connection at the PCM is good too.
jnicewan is offline
post #3 of 3 Old 09-09-2012, 07:30 AM Thread Starter
pushinacoach
Well, finally got the problem solved. It was the wire harness that runs behind the head to the fuel rail. It had chaffed on the head bolt and 4 wires were exposed and shorting. Wires spliced and harness repaired and no more problems. Thanks for the help.
