2003 Liberty makes humming noise and vibration during deceleration - JeepForum.com
post #1 of 5 Old 10-24-2013, 10:48 AM Thread Starter
bhawkins1978
2003 KJ Liberty
I have a concern regarding the noise being generated when i decelerate. The car runs perfectly fine if i keep it at low speeds like when I drive around the neighborhood. When I manage to get it up to about 30+ MPH, when i let off the gas, I can hear a faint humming sound. When i put my foot back on the gas, the humming goes away. As I decelerate, the humming becomes a bit more noticable, and if i break, it becomes very noticable, and i can feel a slight vibration in the petal and in the floor when it gets down to about 10 MPH to when it stops. I rarely get to real highway speeds, but i'm pretty sure the last time I did, I heard the same faint humming while driving at a constant speed of 65-70 MPH. Though, like I said, none of it happens if i keep the car at slow speeds, so I'm pretty confident it doesnt have to do with the brakes or wheels.
Recently (3 weeks ago), I had the transmission fluid changed, and found that it was about a half qt low in fluid, which i've since added. I've read that it might be the u-joints on the driveshaft, but if it was them, wouldnt the vibration occur during acceleration as well, or at least every time the car was decelerating?
Can anyone relate to this problem, or have any recomendations of what might be the cause?
bhawkins1978 is offline
post #2 of 5 Old 10-27-2013, 01:36 AM
LJameson
Could be the upper control arm bushings are bad, causing the driveline angle to be off when you decelerate.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #3 of 5 Old 10-30-2013, 02:07 AM
JohnCrabtree
1994 ZJ
Could be a tire imbalance. A Radial Imbalance will be evident at low speeds also, however, a dynamic imbalance may only be evident at high speeds.
Bent driveshaft or a weight fell off of the driveshaft. That would be noticable when accelerating also, however, your engine may be making too much noise for you to hear it.
JohnCrabtree is offline
post #4 of 5 Old 11-02-2013, 07:14 PM
rjbruzan
The reason it hums is it doesnt know the words.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is online now
post #5 of 5 Old 11-03-2013, 01:42 AM
Evildriver-3
Check your rzeppa at the front shaft
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
driveshaft , noise , transmission
