2002 overland transmission - JeepForum.com
post #1 of 3 Old 01-31-2013, 01:43 PM Thread Starter
Mikey_Overland
Was wondering if anyone could help me on this one. When I put my jeep into drive sometimes it jerks really bad. I have taken it into transmission shops and there telling me nothin is wrong. Could it be a sensor?
Mikey_Overland is offline
post #2 of 3 Old 02-03-2013, 10:08 AM
jokerchief462
Usually when that happens it is a lck of pump pressure. You get a slight delay and then BAM!!! So depending on your miles a fluid and filter change or go to the shop and have it flushed. On newer like yours it will throw a code when the sensors are baad you should have a low and high speed sensoe along with a vehicle speed sensor (speedo only). If you can't do it your self take it to the shop.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 3 Old 02-03-2013, 10:23 AM Thread Starter
Mikey_Overland
Thanks for the advice dude.
