2002 Liberty 3.7L Power Tech V6 Engine Question - JeepForum.com
post #1 of 2 Old 05-25-2005, 03:12 PM Thread Starter
Pete Mitchell
Hi Everyone.....
May be a stupid question. I have the 2002 Jeep Liberty with the engine in the title...Was looking around and CAN NOT find Sparkplugs let alone wires and a distributor. HELP! Where are these suckers! Would anyone have a link to a good diagram of the engine?
Pete Mitchell is offline
post #2 of 2 Old 05-25-2005, 08:47 PM
brandoncrone
Hi! There are no plug wires and a distributor as Jeeps used to. Each cylinder has a coil over the plug. If you look at the engine near each fuel injector will be a 2" square black plastic box with a 2 wire connector attached and it is held down with one 10mm nut. Remove the nut, unplug the connector and remove the coil from the cylinder head. Way down in the bottom of the hole is the spark plug. For the right bank it gets a little tricky with the coolant resovior in the way.
Hope that helps!
Dodge/Chrysler/Jeep Technician 14 Years
ASE Master Certified
L1 Advanced Engine Performance
brandoncrone is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
2002 Liberty 3.7L Exhaust Clamps.....WTF? C3Killer Engines & Drivetrain 0 01-18-2010 12:16 PM
2002 Liberty Limited Fog Lights SiRCRX Audio, CB & Ham Radios, GPS, & Electrical 0 04-27-2009 04:45 PM
2002 jeep liberty 4wd deklet Tires & Wheels 0 09-07-2008 03:02 PM
Power Tech 3.7 Engine Swap icarus00000 Engines & Drivetrain 1 01-12-2003 03:01 PM
