2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine
NOTCH CUSTOMS - Max Clearance Fender FlaresZone Offroad Suspensions Now At FUELED 4WD!New Products From Factor 55 Now Shipping At FUELED 4WD!
Unread 06-25-2009, 10:45 AM   #1
1SickWS6
Okay, this is driving me nuts! I have a 2002 Jeep liberty with a blown 3.7L engine. I am going to replace it, but am having trouble finding a 02/03 engine around here locally. I find plenty of 04/05/06 3.7 engines and was wondering if I would be able to drop one of those in? I understand they have different crank reluctor wheels and possibly cam reluctor wheels. I was thinking of putting a 04 engine in and then also swap my PCM for a newer 2004 PCM with the later engine tune that should be calibrated for the 04 engine. Does anyone have any knowledge if this should work? I would expect the wiring harnesses to be the same between the 02 and 04 engines and would think everything would just bolt right up and fire up. Any input would be greatly appreciated, thanks!
1SickWS6 is offline   Reply With Quote
Unread 06-26-2009, 05:12 PM   #2
iluvtruenos
Basically, all engines are mechanically identical (Your 1976 Chevy 350 V8 and 1999 Toyota Corolla I4 all work the same) You can do it, but you must make both motors identical, this may include swapping sensors, tone rings, and other stuff like that.
It can be done though.
My Jeep is a chick magnet with reverse polarity.
Rampant Pack of Retards group president.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline   Reply With Quote
Unread 07-01-2009, 06:51 PM   #3
nubby
DONT DO IT..................i tried an 04 3.7 in an 03 liberty.....after a month still trying to figure out how to make it work........
for example, had to swap the crankshaft, all sensors, injectors and it still doesnt run right. and modifying the pcm info doesnt work right either
nubby is offline   Reply With Quote
Unread 07-01-2009, 10:54 PM   #4
iluvtruenos
Ohh! The dreaded tone ring issue. 1999-2001 4.7 V8's had 16 teeth tone rings, and 2002-2004 had 32.
I hear your pain.
Just swap those two out, and use all the old electronics.
Unread 08-09-2012, 10:31 PM   #5
old45b
2003 KJ Liberty
Easy fix
This is actually an easy fix.
When you change out to a newer motor, you have to do a few things to make it work.
1.Change the reluctor to the original one from your vehicle.
2.Change the cam sensor to the original one.
3. make and install an egr block off plate if yours did not have one.
4. Use the original instake and connectors if different.
I did this to my 2003 Liberty to a 2007 motor and it worked perfectly.
Drives like a new car and I now have 2000+ miles on my swap.
Good luck and good driving. You will enjoy your Liberty.
old45b is offline   Reply With Quote
Unread 01-14-2013, 06:14 PM   #6
tommxxx
2004 KJ Liberty
hi i am also looking to put a 2004 3.7 Liberty motor in my 2002 Liberty it is also a 3.7 so all i need to do Change the reluctor,cam sensor, install an egr block off plate original one from the 02.
tommxxx is offline   Reply With Quote
Unread 04-09-2013, 11:07 AM   #7
Griff1918
Now how involved is this swap? Do I have to pull the crank shaft to do the swap?
Because if it is super involved I just get a remaned engine and have all new inners.
Griff1918 is online now   Reply With Quote
Unread 04-09-2013, 11:16 AM   #8
tjkj2002
2002 KJ Liberty
You will have to pull tha oil pan off and the valve covers,not 100% sure if the crank has to be removed though.It's a pretty involved job,not hard just takes some time.
tjkj2002 is offline   Reply With Quote
