2002 Jeep GCL - Hit and Misfire (1/6) / Rough Idle - JeepForum.com
post #1 of 6 Old 12-29-2012, 12:10 AM Thread Starter
lhsbrad35
Hi there,
I am Bradley Windhorst and I own a 2002 Jeep GCL above Pittsburgh, PA. I recently just bought it - listed when sold that there was a hit and miss - drove it around and didn't notice it, although we had to jump-start it each time (most likely cleared the codes then). But, anyways, code P300, P301, and P306 come up which are random misfire, misfire on cyl. 1, and misfire on cyl. 6. We replaced the cam shaft sensor, the coil system, thought it could be the computer and replaced it, but nothing has worked - problem only occurs when idling...it straightens out when you are on the gas...and it will straighten at certain times and then run fine for a while, but then just comes back a day later or so. Also, when it acts up, sometimes you can restart it and then it clears for a while...we have taken to two different places and nothing has worked - spent too much money on this to not figure it out - the fuel injectors seemed to be tampered with aka they were numbered by paint...but both shops said they seemed fine - again - it runs well for a certain time period and then it starts to rough idle and then hit and miss real badly...any ideas or suggestions???
- Must be electrical because I can drive it when it doesn't act up and it runs real well when it doesn't.
Thanks.
lhsbrad35 is offline
post #2 of 6 Old 12-29-2012, 06:36 AM
2001SLVSTNTJ
sounds exactly like mine, I also had it in 2 different shop (1 being the dealer). The dealer said that a comprssion check showed cylinder #3 with low compression. I brought it home and checked myself and confirmed that the compression seems low in #3 but still trying to determine exactly why before going any further. Very frustrating I know, i will let you know what i find please do the same if you would. I have a thread titled "compression numbers...what next". Good Luck!
2001SLVSTNTJ is offline
post #3 of 6 Old 01-02-2013, 01:01 PM Thread Starter
lhsbrad35
Called the dealer the other day and such...will be taking it in the shop probably this afternoon so I should here something...good or bad...eventually throughout the week.
post #4 of 6 Old 01-02-2013, 01:34 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Injectors were numbered so the shop knew which one was from where, when they swapped them around. A VERY logical thing to do, so no worries there.
Next would be a compression check, vacuum check and HG check. Do those and post results.
I would suggest swapping coils, plugs, injectors around, but it sounds like that has been done already.
Another thing it could be, is the injector plug itself. Had that on one rig ages ago.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #5 of 6 Old 01-11-2013, 12:24 AM Thread Starter
lhsbrad35
Alrighty thanks so much...they will most likely be giving a diagnosis some time tomorrow hopefully.
post #6 of 6 Old 01-12-2013, 08:32 AM
2001SLVSTNTJ
if you get a chance let us know what they say. Thanks! I used a block tester and it seems there is not the head gasket, still checking mine out.
electrical issue , misfire , P300 , rough idle
