2000 xj 4.0 runs like crap! - JeepForum.com
post #1 of 7 Old 08-26-2013, 06:33 PM Thread Starter
6inchyj33s350
I bought a 2000 Jeep XJ 4.0 for $400
The PO said it sat, then wouldnt start, then they changed the Cam Sensor and now it starts and runs, but runs like crap!
-It has a consistent miss, from idle through all rpms, like its not running on all 6 cyl, whether cold or warm never different
-Has new Spark plugs, gapped correctly, the #5 plug was wet with fuel when I changed it
-I re-adjusted the cam sensor, even tried flipping it 180 and no change!
-I installed new crank sensor
-I can pull the #5 injector plug while idling and theres no change in idle.
-I swapped the #5 injector with #1 and no change when #5 is unplugged.
-I have not yet read codes, fuel pressure appears to be great, saw no cracks etc on coil rail while it was off, I have not tested compression yet, airbox is clean.
ANY IDEAS???
Thanks, Cory
6inchyj33s350 is offline
post #2 of 7 Old 08-27-2013, 03:13 PM
uberxj92
1992 XJ Cherokee
It may be a bad distributor cap. Broke on #5.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 7 Old 08-27-2013, 06:30 PM Thread Starter
6inchyj33s350
no distributor on my model, it has coil pack on plug. i wish it had a dizzy... Im going to try to a comp. test on all cylinders this weekend...
post #4 of 7 Old 08-27-2013, 07:29 PM
uberxj92
1992 XJ Cherokee
Let us know results.
uberxj92 is offline
post #5 of 7 Old 12-14-2013, 07:12 PM
shturner1975
Any updates on this? I'm having similar issues with my 02 model. Wet plug, missing, etc.
shturner1975 is offline
post #6 of 7 Old 12-16-2013, 02:35 PM
jimhensley
Bad MAP sensor?
jimhensley is offline
post #7 of 7 Old 12-17-2013, 08:49 AM
Purcell69
With a wet plug and constant miss on #5, I'd suspect the coil pack is bad. Put a test light on it and see if there is power to fire the plug at #5.
-Joe
Purcell69 is offline
