2000 wrangle sport 4.0 stalls randomly - JeepForum.com
post #1 of 2 Old 05-23-2012, 08:07 PM Thread Starter
h10weaver
Hi, I'm new to the forum and love my jeep. I have a 2000 wrangle sport 4.0 auto and it has been stalling randomly, while stopped or driving. I would really appreciate it if anyone can recommend the best jeep mechanic in south eastern Michigan. I have had it looked at by a few local mechanics and a friend has had Chrysler engineers give crappy advice. It starts right back up and is not giving any codes. Asd valve opening when not supposed to, crank sensor and computer brain are new, no help. Thanks in advance for any help!
h10weaver is offline
post #2 of 2 Old 05-23-2012, 08:54 PM
Cvarney
My 05 would do this occassionally. It was a 2.4 but it was the battery. MY negative post (i believe) had corroded really badly, enough that it ate through the post some. Even after I cleaned it it would still happen. Once or twice while driving, mostly when comming to a stop. It didn't happen enough that I would call it a regular thing, but it was enough to keep my mind on it. I didn't notice the terminal being eaten up till I went to replace the battery and then a couple weeks later wiring up a winch I broke the terminal. It had been eaten a little bit as well from the corrosion I suppose. If you've ever had any problems with that I'd check out your battery first, clean up the terminaly and posts really good and smear a little di-electric grease on it. i haven't had a problem since, granted it's only been about a month but no corrosion and no more stalls.
Cvarney is offline
