2000 jeep grand cherokee high rpm rattle - JeepForum.com
post #1 of 14 Old 09-10-2013, 08:27 PM Thread Starter
99wjmaverick
Hello, i have a 2000 jeep grand cherokee 4.0, and at rpms over 2000 it rattles pretty bad and loses oil pressure once warmed up. it has 160,000 miles. Anyone have any idea whats wrong with it?
99wjmaverick is offline
post #2 of 14 Old 09-11-2013, 02:24 PM Thread Starter
99wjmaverick
bump
post #3 of 14 Old 09-11-2013, 02:34 PM
brouwmat
I don't know what that one would be.. when you say "Rattle" what does it sound like? Any codes? don't rely on the idiot light.. hook it up to a computer and see if it has any codes there.
brouwmat is offline
post #4 of 14 Old 09-11-2013, 04:28 PM Thread Starter
99wjmaverick
Alright, it almost sounds like something is in the fan.
post #5 of 14 Old 09-11-2013, 07:42 PM
brouwmat
Clutch driven fan or electric fan? If it's the clutch driven fan that would be my guess..
brouwmat is offline
post #6 of 14 Old 09-14-2013, 10:56 AM Thread Starter
99wjmaverick
electric fan.
post #7 of 14 Old 09-14-2013, 08:09 PM
uberxj92
1992 XJ Cherokee
Probably bearing on fan. Oil pressure can anything.
You can change oil and filter.
Test pressure with mechanical gauge.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #8 of 14 Old 09-18-2013, 04:10 PM Thread Starter
99wjmaverick
I had somebody look at it and they said main bearings or cam bearings, anyone know how to find out which it is?
post #9 of 14 Old 09-18-2013, 08:38 PM
DonBray2
Sounds like cam bearings and the rattling is probably the lifters losing oil from lack of pressure.
Jeepseeker1
DonBray2 is offline
post #10 of 14 Old 09-18-2013, 08:58 PM
uberxj92
1992 XJ Cherokee
X2 if it were mains you'd here them
uberxj92 is offline
post #11 of 14 Old 09-18-2013, 09:10 PM Thread Starter
99wjmaverick
alright thanks. Would it be worth having the cam bearings replaced or find a junkyard engine?
post #12 of 14 Old 09-18-2013, 10:10 PM
uberxj92
1992 XJ Cherokee
Junkyard engines are hit or miss on whether they are good or bad.
If your gonna do the can bearings may as well rebuild the engine.
Craigslist is a good source for running engines.
uberxj92 is offline
post #13 of 14 Old 09-19-2013, 06:11 AM
brouwmat
if you don't have the ability to rebuild the engine yourself, I would look at a reman. Mine was about $1900 + install. Most junkyard engines worth anything are going to be in the same range + the same install. The reman comes with a 3yr Unlimited mileage warranty that may cover labor (depending on who you buy it from of course) where your junkyard motor will be lucky to have a 1yr parts warranty.
brouwmat is offline
post #14 of 14 Old 09-20-2013, 05:36 AM
DonBray2
X2 on the reman. You can't beat the price plus you get a warranty.
Jeepseeker1
DonBray2 is offline
engine failure
