2000 4.0 Wrangler Misfire - JeepForum.com
post #1 of 1 Old 04-28-2010, 09:02 AM Thread Starter
peeweeXJ
I have a consistent cylinder 1 misfire. It happened immediately after I started the Jeep a couple of weeks ago.
I used my spark tester, and found I do have good spark at cylinder 1.
I also checked to make sure my valvetrain was intact. And yes, it is.
I then checked the fuel system.
Using my stethescope, I realized that upon startup, the fuel injector will pulse normally. Then about 15 seconds into the runtime the injector will completely flatline. No movement whatsoever.
I tested the fuel injector, and it's resistance was comparable to the others, but I decided to replace it just in case. No change.
At idle injector #1 is getting around 5-6 volts, fluctuating as usual.
ANY HELP?
The last thing I want to do is bring it to the stealership,
Thanks!
peeweeXJ is offline
2000 4.0L WJ Misfire Codes P0300 + other P030X WillySLC Engines & Drivetrain 1 02-08-2010 08:26 AM
Small Block Convertion in a 2000 Wrangler dblanch Engines & Drivetrain 4 06-22-2009 02:03 PM
2000 jeep wrangler add a supercharger??? tmoney Engines & Drivetrain 10 05-23-2008 08:41 PM
will these tires fit on a 2000 jeep wrangler without any lift?? tording Tires & Wheels 5 10-27-2003 03:57 PM
2000 Sahara My first Wrangler JeepDelaware Tires & Wheels 0 06-08-2003 07:44 PM
