2 barrel carb replacement - JeepForum.com
post #1 of 4 Old 01-08-2013, 04:37 PM Thread Starter
bigtom89
I have a 88 YJ with the 4.2l. My carb is now idleing rough, at speed it's ok but the idle jumps. It has a new jasper motor with about 5k on it. I've been reading actually seeing videos of guys running Mopar 2bbl carbs. Everything I hear and read say its a far better carb then the stock one. The only problem I am not seeing which carb to buy. I already took off the electric choke on the stock on and I want to stay with a manual choke. Any help and advice is greatly appreciated.
1988 Wrangler YJ, 4"lift on 33" BFG Mud Terrians
bigtom89 is offline
post #2 of 4 Old 01-09-2013, 05:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Check this out. Very common problem, and easy fix.
Make sure your intake manifold bolts haven't loosened up, too.
http://www.jeeptech.com/engine/carter.html
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 4 Old 01-09-2013, 06:57 PM Thread Starter
bigtom89
Thanks, that was a lot of help and after some cleaning and a few adjustments its idling smooth.
bigtom89 is offline
post #4 of 4 Old 01-10-2013, 06:13 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Cool. Cheaper than a replacement, huh?
4.2l , carb , idle , jeep , wrangler
