2.5L, YJ to TJ difference? - JeepForum.com
post #1 of 5 Old 04-21-2009, 09:35 PM Thread Starter
psycopanther
what all do i need? i know the sensors are different, but are all the sensors different? is it just some of the connectors that make them different? ECU still the same? i got the 99 ECU and engine harness, but no sensors off the stock block. what will i be needing to do to make the YJ 2.5 work in my TJ?
psycopanther is offline
post #2 of 5 Old 04-22-2009, 09:31 AM
Kip03TJ
What year YJ? The only thing that I've ever heard of is the water pump on one of the years/or models is reverse rotation of all the other 2.5's. But you'll be fine going from a YJ to a TJ. It's the same engine but adds a few more sensors, nothing major changed and I think you'll be able to start it with the 99ECU and harness.
FOR SALE
14,960 miles perfect condition
2003 Jeep Wrangler Sahara edition fully loaded 5 speed manual. Brown dog 1" motor mounts, Currie 1" body lift, jks front disconnects, 31" Goodyear Wrangler duratracs, 8 adjustable control arms, Advance Adapters HD SYE, Tom woods premium driveshaft, driver & passenger heated seats
Kip03TJ is offline
post #3 of 5 Old 04-22-2009, 11:49 AM Thread Starter
psycopanther
sweet, anyone else confirm this? and what other sensors would i need? oh and it is coming from a 95 (hopefully). the transmission is from a 99 also.
post #4 of 5 Old 04-22-2009, 03:35 PM
TomZ
If you plan to use it on the street, you might want to check with your state's DMV to see if they will approve this swap. My state won't allow the installation of a motor from a vehicle that is older than the recipient vehicle.
TomZ is offline
post #5 of 5 Old 04-22-2009, 08:25 PM Thread Starter
psycopanther
we have no smog test or any of that stuff here. at least not yet
Need to know the difference between PSC.............. OffCamberTJ Fabrication Shop 2 02-05-2007 09:30 AM
Wow what a difference with gas Psyker Fabrication Shop 1 11-20-2006 10:22 PM
What's the Difference Between... Canuck262 Tires & Wheels 3 11-10-2005 03:13 PM
is there really any difference?? drummerwookie General Jeep & Off-Road Equipment 2 10-18-2005 06:42 PM
how do you tell the difference 304/360 Notplayn Engines & Drivetrain 4 03-11-2004 04:35 PM
