2.5L Engine dilemma - JeepForum.com
post #1 of 5 Old 01-15-2005, 01:28 PM Thread Starter
Jerry All-Bran
Jerry All-Bran's Avatar
2.5L Engine dilemma
Everytime I turn the steering wheel, the engine squels as if complaining that something is wrong. I thought it could be the alternator or possibly the bearings but i cant say sor sure. It's making a screeching noise that seems to originate from inside the engine almost when the wheels turn. Any help would be very much obliged.
Jerry All-Bran is offline
post #2 of 5 Old 01-15-2005, 02:32 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Have you checked the power steering pump or belt?
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 5 Old 01-15-2005, 02:45 PM Thread Starter
Jerry All-Bran
How or where can i check that? My knowledge if pretty limited on most mechanical components Still learning since i only got this jeep a few months back, but what could it possibly be? I mean, i guess it could make sense that it's the belt, b/c the engine is affected by turning the wheel and she sounds different.
post #4 of 5 Old 01-15-2005, 04:02 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If the PS fluid is good, then chances are the belts loose, when you turn the wheel it causses the pump to load, and the pulley is slipping. You need to either tighten or replace the belt. If you don't know how to do it, then go buy a Chilton manual. It will give you step by step instructions.
jeepdaddy2000 is offline
post #5 of 5 Old 01-15-2005, 04:49 PM Thread Starter
Jerry All-Bran
Thanks a lot, really appreciate the help. Going to go purchase the manual and with any luck i'll be able to remedy the problem. Thanks again!
Tire dilemma mscottz Tires & Wheels 11 03-13-2009 01:02 PM
locker dilemma? tbonz1128 General Jeep & Off-Road Equipment 3 11-05-2008 02:33 PM
new amp dilemma HELP LiBMXr1390 Street Jeep Forum 13 03-31-2008 02:04 PM
Yet Another Mud Tire Dilemma tcestes Tires & Wheels 3 11-11-2006 09:50 AM
