2.5l Cam - JeepForum.com
post #1 of 8 Old 01-18-2005, 11:48 PM Thread Starter
Greencar
Greencar's Avatar
2.5l Cam
has anyone had experience with the 2.5liter cams that clifford makes??? I am looking at this one. http://www.cliffordperformance.com/c...am_3228528.htm
I am just looking for some cheap power. Thanks
-Dan
Black 1994 YJ 2.5L
SOA
Greencar is offline
post #2 of 8 Old 01-19-2005, 08:30 AM
BamaJeeper
BamaJeeper's Avatar
Not much info from that link. It's a .270 lift and a stock cam is .265. That cam will give an itty bit more performance in a slightly higher RPM range. Definitely not worth the $200. Look on ebay and similar sites for cams and call your local dealerships to see what's available.
Are you looking for more power in the lower RPMs when off-road or higher RPMs while on the road?
Here's some more info you should read.
http://www.chevytalk.com/tech/101/Cam_Theory.html
Out of the darkness comes light.
BamaJeeper is offline
post #3 of 8 Old 01-21-2005, 11:36 PM
mrgeoff
Hello there. I have the same engine in my 93 YJ. There isent much you can do to get more power. Your best bet is gearing or engine swap, but neither is cheap. I run 5.38 rearing in my 4 banger YJ. best thing i ever did.
mrgeoff is offline
post #4 of 8 Old 01-27-2005, 12:24 AM Thread Starter
Greencar
Greencar's Avatar
Hey thanks for the info. I was looking at this page again and this cam has .523 lift, the duration is .270
-Dan
Black 1994 YJ 2.5L
SOA
Greencar is offline
post #5 of 8 Old 01-27-2005, 08:14 AM
JEEPINWI
Greencar-
I know there is a 2.5L camshaft on eBay right now. Here it is: camshaft . Also, if you use a camshaft with more than .450" lift, you will definitely need new valve springs. You do not want to experience valve float at higher RPM's, and that would definitely happen with a cam of .523" lift and stock valve springs.
Brian-
99 XJ Cherokee, 2 door, 4.6L Stroker, 5 speed, 4x4, 8.25" rear, 3.07 gears
JEEPINWI is offline
post #6 of 8 Old 01-28-2005, 05:45 AM
BamaJeeper
BamaJeeper's Avatar
Oops. I must have been dead assed tired when I posted that cause I don't even remember posting it.
My Mopar cam has .440" lift and made a significant difference in low RPM torque. I believe .440 is as far as you can go before having to install different springs.
post #7 of 8 Old 01-28-2005, 08:58 AM
STW
What drawbacks would/does that .440 cam have at higher rpm? Been looking for a low rpm torque cam (RV cam?) like that myself and I don't mind if it compromises hp above 3000 rpm, but don't want it to mess with hp below that with too short an overlap duration. What do you find with rpm at 3000 or so?
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #8 of 8 Old 01-29-2005, 05:30 PM
BamaJeeper
BamaJeeper's Avatar
I could'nt tell any difference above 3k.
