2.5 yj engine - JeepForum.com
post #1 of 3 Old 04-30-2002, 01:27 PM Thread Starter
scigs
2.5 yj engine
I am taking my 1992 yj to the shop for a new timing chain. I had my compression checked and I am running 150 in all cylinders. Not burning oil and engine runs strong other than the noisy chain. I was wondering while they have everything apart if I should have the oil pump and water pump changed also? or just save my money. water pump will be an extra 100.00 and oil pump 300.00?
d.s
scigs is offline
post #2 of 3 Old 04-30-2002, 01:29 PM Thread Starter
scigs
forgot to mention eng. has 141,000 miles
d.s
scigs is offline
post #3 of 3 Old 04-30-2002, 01:58 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Definitely do the water pump, hell it's off anyway, it'll cost more than $100 to do it later. (This is assuming of course, that you are having the work done, not doing it yourself, as it seems.)
The oil pump, I would personally do if your oil pressure hasn't been up to snuff. However, how does the oil pump mount on the 2.5s, is it inside the pan, therefore altogether separate from the timing chain change? If so, don't bother having it done, it won't save any money on labor. I am assuming this is the case, or else it wouldn't cost 300! Oil pumps are cheap, it is all labor.
4wheeler4CJ is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Anyone use an engine lift plate with a leveler to pull an engine? tankcj Engines & Drivetrain 2 08-06-2008 02:29 PM
Engine differences between 89, and say 96 Engine Techies PLEASE step in JolshkerLS1 Engines & Drivetrain 4 02-27-2003 10:29 PM
replace 4cyl engine with 6cyl engine eastwood Engines & Drivetrain 5 01-23-2003 08:19 PM
