Quantcast 2.5 takes long to start/hard starting - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 2.5 takes long to start/hard starting
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 03-29-2009, 09:23 PM   #1
ed695
hello please help me out i have a 1997 jeep tj 2.5 with 184000km everytime i go to start it, it cranks for quite a while then eventualy fires, now i already looked at a few things such as, when i turn the key i can hear the pump run, i replaced the rotar, cap, wired and plugs... what seems to be working right now is to turn the key on and off three times then start it, it fires pretty much right away does anyone have any ideas or advice thanks
ed695 is offline   Reply With Quote
Old 03-29-2009, 09:52 PM   #2
twiz
1989 XJ Cherokee
There's a check valve in the pump that can go bad and what happens is the fuel drains back into the tank after it's shut off. When you go to start it the pump has to fill the lines up with fuel before it can start to build pressure, this will delay the starting. By cycling the key on and off you are filling the lines up with fuel and helping it to build pressure. You have to replace the pump to fix it or just cycle the key before you start it and take care of that problem if the pump goes out.
twiz is offline   Reply With Quote
Old 03-29-2009, 10:04 PM   #3
twiz
1989 XJ Cherokee
I did some checking and that has a returnless fuel system. There's a regulator on the top of the fuel pump assembly that could be bad.
Old 03-30-2009, 11:40 AM   #4
ed695
thanks for the help, could it be something else such as a clogged line, crank sensor or something else? pumps are expensive and just want to make sure that thats the prob thanks again
Old 03-30-2009, 01:03 PM   #5
ed695
would also like to add that when its running it runs great
Old 03-30-2009, 02:15 PM   #6
peaceinvermont
same problem!
I have recall on sending unit,so when there in the area i want to replace everything! (extra charge) fuel pump/regulator & filter...am i missing anything else? I will also have them install new purejeep gastank skid,whenever it gets here,lol (hope all this will fix my starting prob.) GOODLUCK w/yours also!!
97' (black)TJ wrangler 2.5/ax-5 & D35/D30,Riddler diff.covers,4.11 gears 4"lift (springs) 4" rancho shocks,adj.front trackbar w/rear location bracket,JKS quicker discos,AEM air intake,Jet chip,airraid spacer,dynomax exhaust,BFG 33"12.5 tires on american race steelies,f.warn bumper/LOD rear bumper/tire swing & sliders,7"fender flares,p.steering cover,purejeep gastank skid,Hi-lift jack & recovery gear/tools,updated sound,neoprene s.covers & etc.
peaceinvermont is offline   Reply With Quote
Old 03-31-2009, 09:52 AM   #7
ed695
took my jeep into the shop when the jeep is running the pressure is fine as soon as they shut it off i loose it all right away they are saying i need to replace the pressure regulator, so i will end up changing the pump, filter, regulator and other components in the tank..... will post if this works thanks for the replies
Glock Forum
