2.5 goodies to get.. - JeepForum.com
post #1 of 6 Old 02-13-2003, 11:34 AM Thread Starter
JSBlu974X4
i got a 2.5, its got about 40,000 miles on it, was a total rebuilt engine new block and everything, i wondering what can i get to give me hp but i not put out a HUGE amount?jet chip?
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #2 of 6 Old 02-13-2003, 01:19 PM
Dr Gutiemouth
Dr Gutiemouth's Avatar
i got a 2.5ltr also...from what i have read on this forum its really not worth the money to get all the mods to give you more HP. but thats just what i have read..i am more than likely wrong. i dont know if you have been off road yet but i havent and i dont plan on doing any engine mods untill i see how it preforms off road...i was talking with a guy i work with about some bolt on hp and he told me i should be fine with what i got and told me not to under estimate the 4 banger. i guess we'll see what happens on the trail...
Green Jeep Club Member #39
The Almighty 2" BB Jeep Club Member #2
*outdated
Dr Gutiemouth is offline
post #3 of 6 Old 02-13-2003, 01:37 PM
devinf
Simple things to do would be...
Remove the air restrictor
Put in a high flow air filter
Install a 4.0L throttle body
And I'm sure if you look around the forums there'll be a how-to or a link to somewhere that can show you.
Devin
'94 YJ 2.5L 5-spd, 30x9.50
White Jeep Club Member #65
devinf is offline
post #4 of 6 Old 02-13-2003, 04:28 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Gear swap would be the best bang for your buck. 4.56's or 4.88's
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #5 of 6 Old 02-13-2003, 10:05 PM
hjeepxj
hjeepxj's Avatar
gears are the best......
1. Cold air intake with 5" Powerstack cone filter
2. 4.0 TB with taper bored to 60mm
3. Poweraid TB spacer bored to 60mm
4. Intake manifold heatshield
5. Flowmaster 50 series 2.25" muffler
6. High-flow cat
7. Clifford Performance header with 2.25" piping
8. Champion copper plugs
9. Magnecor 8.5mm plug wires
10. Electric fan conversion
11. Speedtweaks IAT adjuster
With the package of mods listed above, output should improve by 20% to about 145hp.
88 Jeep Cherokee, Lots of Mods.
hjeepxj0.tripod.com
"Im okay, im alright, just might get a little high tonight, im okay, im alright, CARRY ON!"
-Pat Green
hjeepxj is offline
post #6 of 6 Old 02-14-2003, 05:00 PM
wrangler john
I just dropped back in the 2.5 in my 95 wrangler. Bought it very cheap with a blown engine(the previous owner double gasketed the oil filter and lost all his oil on the road). with the minor mods that I did I did see a change in torque in the lower rpms and it does pull harder in the mid and upper rpms also. This is what I did.
new crank and bearings
honed cylinders and replaced rings
installed new cam bearings
installed a mopar performance camshaft and lifers .450 lift 108
centerline 258 duration
Mild head porting
bosch platinum 4 spark plugs.
no exaust or intake mods yet.
to anyone out there you just have to realize what your expectations are before you start. If I wanted massive torque and horsepower, I would have went for a v-8 conversion or a 4.0 swap. There is a old rule that I was taught a long time ago. There is no replacement for displacement.........
Some people thing 1 jeep is enough, But I had to have 3!!!
wrangler john is offline
Some go fast goodies / Modernization goodies AMCSportTruck Engines & Drivetrain 0 02-04-2010 09:28 AM
High Flow cats, and other bolton goodies Tatersaladx Street Jeep Forum 19 11-15-2009 05:10 PM
Goodies for my TJ - What to get TellicoTJ General Jeep & Off-Road Equipment 3 11-07-2008 09:32 AM
Considering Some Performance goodies Slammed_Am Street Jeep Forum 53 06-15-2007 09:46 AM
New Harbor Freight goodies...winch/U Joint tool (MJR X-post) jmbrowning General Jeep & Off-Road Equipment 1 08-07-2003 03:27 PM
