2.5 4cylinder engine swap.... - JeepForum.com
post #1 of 3 Old 07-14-2005, 11:08 AM Thread Starter
KD5LEF
KD5LEF's Avatar
I want to know (yes I searched) what it would take to swap a 6cyl engine from a 88 XJ to a 97TJ that currently has a bad head on its 2.5 ltr 4cylinder.
More specifically what am I looking at as far as tranny and transfer case compatibility. I know I will need the wiring from the XJ but was also wanting to know if there were any adapter harnesses for it.
Thanks in advance for the info.
1 Divorce.....countless $$. 2004 Jeep Rubicon - Armored, lifted, new tires, wheels, tire carrier. Winch to come - PRICELESS!!
3inch OME, JKS goodies, 1.25BL. 33x12.5 BFG KM2's
KD5LEF is offline
post #2 of 3 Old 07-15-2005, 09:48 AM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
You do realize that the V8 is more than likely not fuel injected right?
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #3 of 3 Old 07-25-2005, 02:37 AM
TXjeepTJ
TXjeepTJ's Avatar
im positive you'll need adapters for its motor mounts you might want to check out www.advanceadapters.com
i have a 97tj also, but instead of going through all the trouble of an engine swap(just dont want to do new wireharness and weld new motor mounts) im just gonna find a 6cylinder jeep with high miles and rebuild it while stroking it and boring the heads out along with a nice cam to give me that v8 sound... thats just me tho lol
swaping a v8 into would require ALOT more stuff than swapping a 6cylinder you prob. know that tho i bet haha hope i helped!
TXjeepTJ is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
cummins 4cylinder or mopar v8? mopars69 Engines & Drivetrain 37 09-26-2008 07:47 PM
4Liter swap into a 4cylinder YJ? Huntersbo Engines & Drivetrain 3 09-29-2006 05:36 PM
Has anyone broken a Super35 with 35x12.5s on a 4cylinder? Dave Taylor Tires & Wheels 13 03-27-2004 05:50 PM
