1999 Jeep Grand Cherokee, 375, 000 mi. - JeepForum.com
post #1 of 7 Old 10-24-2013, 08:36 AM Thread Starter
Futuramic76
Great car, original owner, freq.oil changes.
Replaced my Crank sensor, alternator, MAP sensor. Engine is sputtering on warm start ups until I get on freeway. Gas mileage is down by 40%.
Fuel injectors?
Cam shaft sensor?
Spark plugs?
Vacuum leak?
Likely issue?
Futuramic76 is offline
post #2 of 7 Old 11-01-2013, 07:11 PM
uberxj92
1992 XJ Cherokee
Wow. That's a beast. Got to live it. That's a hefty fuel drop. When was the last tune up? With ethanol you get half life on tune ups nowadays.
Check engine light on?
Could be o2 sensor.
Which engine do you have?
That many miles you may want reward her with a rebuild.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 7 Old 11-01-2013, 07:25 PM Thread Starter
Futuramic76
Just replaced M.A.P. sensor, O2 sensor, fuel injector cleaner.
Think maybe a vacuum leak?
post #4 of 7 Old 11-01-2013, 07:26 PM Thread Starter
Futuramic76
4.7 L all-wheel.
post #5 of 7 Old 11-02-2013, 03:42 AM
uberxj92
1992 XJ Cherokee
Sounds vacuum. That's a lot if mikes on that particular engine. I'm impressed. Keep her up
uberxj92 is offline
post #6 of 7 Old 11-02-2013, 05:17 AM
Duh
I wouldnt rule out a sticking injector. Stuck open it will give a stuttering appearance at times when there is too much fuel and not enough air-think about stoichiometry.
Duh is offline
post #7 of 7 Old 11-03-2013, 04:01 PM Thread Starter
Futuramic76
Thank you guys. I will explore those solutions.
