1999 2.5L skipping @ 2000 rpm only - JeepForum.com
post #1 of 12 Old 11-11-2011, 08:57 PM Thread Starter
bcash616
My jeep runs great except when under a load @ 2000 rpm it will shutter and skid...runs great @ 1900 and 2100, but doesn't like 2k. Especially noticeable in 4th and 5th gear, but I have noticed it in 2nd and 3rd gear as well.
Anyone know what this could be?
bcash616 is offline
post #2 of 12 Old 11-27-2011, 06:10 AM Thread Starter
bcash616
just an update....I recently replaced the camshaft position sensor and cranshaft position sensor with no cure to the 2000 rpm shutter. if i hold it at 2k uphill, it will studder/skip enough to throw a code, which has been an injector 4 open code. should i replace the injectors next?
bcash616 is offline
post #3 of 12 Old 11-28-2011, 02:35 PM
krazzyboy_1
I am having the same issue it is something with the o2 sensor or map in the PCM. If you are going to replace a sensor try the upstream o2 with a good one like NTK.
DOHC 2.4L Turbo.
krazzyboy_1 is offline
post #4 of 12 Old 07-19-2012, 06:00 PM
triple555nickel
My 1999 TJ 2.5 also skips/chuggs/sputters in 2nd-5th gear at exactly 2000 rpm while under load. I am really bummed to hear that it is not the cps. I just ordered one.
I can tell you what has NOT fixed it for me... it is not the mass air flow sensor, it is not the throttle position sensor. it is neither the front nor the rear O2 sensor as I have replaced all of the aforementioned parts. It is also not the plugs, the plug wires, the distributor cap or the rotor. Next up for me is the cps (when it arrives) and possibly a new distributor if I can find an affordable one. Also saw in another thread where someone actually got a code for a bad fuel injector if they held the engine in skipping mode while it was under load. They too complained of a specific rpm where it chugged/skipped/or whatever you want to call it.
triple555nickel is offline
post #5 of 12 Old 09-20-2012, 08:05 AM Thread Starter
bcash616
Update time! OK guys, after spending a small fortune and many late nights in the garage replacing many parts I thought could possibly fix this skipping @ 2k ( injectors,plugs, rebuilt head, cps, every other sensor, and even a new pcm....it still does it....and occasionally will throw a cell p0204 code if I hold it at 2k long enough....please someone help me before I run it off a bridge!
bcash616 is offline
post #6 of 12 Old 09-20-2012, 12:37 PM
idriveatj0214
Hi there,
I had the same problem with my 4 banger it ended up being the TPS (throttle position sensor) for some reason it wasn't throwing the code for it so I thought maybe plug wire or distributor so I did a whole tune-up and wasted my time.. Just my .02. I'd give it a try though man!!
idriveatj0214 is offline
post #7 of 12 Old 09-20-2012, 02:49 PM
hiimadam
I got a 98 that has a similar problem. It feels like I'm driving a tractor.
2.5l as well.
I'm getting a complete 4.0l throttle body from a friend and I'll do some reverse diagnostics for you fellas.
It does sound like it could be
-vacuum leak
-CPS (Cam positioning sensor)
-TPS
-IAC
When you pop off your IAC, clean the inside of the throttle body where the plunger meats the throttle body.
hiimadam is offline
post #8 of 12 Old 09-21-2012, 06:54 AM
hiimadam
Cleaned the piss out of my Throttle body and the seat for the plunger on the IAC.
it now idles @ 800-1000 RPM
Runs, but runs terribly. New throttle body is in the mail.
hiimadam is offline
post #9 of 12 Old 09-21-2012, 09:06 AM Thread Starter
bcash616
FIXED IT FIXED IT FIXED IT.......OMG.....after a year plus of throwing money at it, I finally fixed it!
Someone prior to me had the injector 3 and 4 wires swapped on the injectors. Causes a slew of problems (rough but tolerable idle, really rough idle with A/C on, stumbling off idle throttle resp once, and most mind boggling of all the 2000 rpm skip......
I pulled the factory looking tape away from the wiring harness at the injector rail and noticed that # 3 injector wire was slightly longer than the #4 wire(which was going to each others opposite injector) and took a chance......sure enough it cleaned up the idle, no more stumbling, great idle with A/C on and no skipping at 2 k rpm. What a journey this has been trying to solve....I am doing a happy dance at this time!
Hope this helps anyone that may have the same 2k skipping issue.....very hard for a shade tree jeep newb to diagnose!
bcash616 is offline
post #10 of 12 Old 09-24-2012, 04:38 PM
triple555nickel
bcash616, let me say this slowly and loudly... YOU ARE THE MAN. I said you ARE the MAN!!!!. I just swapped 3 & 4 injector wires and BAM OMG it worked. Hallelujah. I was about to take this thing out back and pour lighter fluid all over it hahaha. I bought this jeep a year ago from a girl who was a one owner. She didn't appear to be a wrench turner which makes me think the wires may have been crossed at the Factory ??? Do you think? There could be thousands of 2.5's sputtering at 2000 rpm and people just keep driving think its a POS. Thank you thank you thank you for posting your solution and very brave of you to switch the wires and crank it up. I think that is a true measure of your desperation haha and mine too. If I had thought of it, I would have tried it too. So cool to be part of a community where we can solve problems collectively. Thanks again!
post #11 of 12 Old 09-27-2012, 06:08 PM
smashtj666
It fixed mine too.thanks guys
smashtj666 is offline
post #12 of 12 Old 09-27-2012, 06:46 PM Thread Starter
bcash616
I am very glad to see others have benefited from this finding....I just about pulled my hair out trying to figure out why my jeep did this. I hope more jeepers can find this post and save time, money, and most of all sanity!
bcash616 is offline
