1998 TJ with P0171 and P0463 engine codes - JeepForum.com
post #1 of 3 Old 05-28-2010, 12:42 PM Thread Starter
rogman67
Check engine light came on and found the codes to be P0171 and P0463. The light came on while my power steering pump was leaking fluid (which has been replaced) and I'm wondering if these codes could be because something is dirty with fluid or debris. I get a little hesitation and a mild rough idle and I'm guessing a possible air flow issue. Any suggestions?
rogman67 is offline
post #2 of 3 Old 06-01-2010, 11:49 PM
oakmckinley
your power steering problem would not cause the check engine light to come on its more of an emissions based system. You have a bad sensor somewhere. I don't have a manual handy but look up the codes online or in a repair manual and go from there.
oakmckinley is offline
post #3 of 3 Old 07-03-2013, 03:10 PM
nmcclure7
P0171 means you're running too lean or the ecu received data from the upstream O2 sensor indicating an abnormally rich correction.
edit:
Oops! didn't realize this was such an old thread!
"ΜΟΛΩΝ ΛΑΒΕ" - King Leonidas I, translates to "Come and take them" in response to the Persian king Xerxes who demanded they surrender their weapons.
nmcclure7 is offline
4.0L WJ. P0171 code. JonM81 Engines & Drivetrain 1 12-07-2009 11:27 AM
Engine error codes, Is this possible? Gr8fulDeadHead Audio, CB & Ham Radios, GPS, & Electrical 4 07-06-2008 04:57 PM
Engine light on, but no codes. 0utback Engines & Drivetrain 4 01-26-2008 04:00 PM
Engine codes Trainer Engines & Drivetrain 2 09-18-2003 02:46 PM
Engine codes Gacherokee Engines & Drivetrain 6 03-07-2002 09:56 AM
