1998 cherokee low oil pressure - JeepForum.com
post #1 of 10 Old 05-08-2014, 05:59 PM Thread Starter
austinkoceja
So I was sitting in a drive thru and it starting making noise and shaking a little ip front and oil pressure dropped and won't go back up unless I put my foot in the gas ...any ideas ?
austinkoceja is offline
post #2 of 10 Old 05-09-2014, 12:18 PM
BIGBADWOLF
Idling too low??
BIGBADWOLF is offline
post #3 of 10 Old 05-09-2014, 10:27 PM
XJTexas
Could be as simple as a cylinder misfiring for some reason. Check your spark plugs and plug wires first and see if that fixes it. You can pull off one plug wire at a time and if you get NO change at all when pulling one of them off then that is your problem cylinder.
XJTexas is offline
post #4 of 10 Old 05-10-2014, 06:27 AM
chapmangm32
Low oil pressure could be coming from a worn oil pump. It may not have gone completely out, which is why you get pressure with higher rpms. First thing I would do is find out exactly where the noise is coming from
chapmangm32 is offline
post #5 of 10 Old 05-10-2014, 07:15 AM
BIGBADWOLF
As long as oil pressure increases with rpm I would not be too concerned. Low pressure at idle is not serious. Mine has had only 4psi for years and thousands of miles.
post #6 of 10 Old 05-10-2014, 01:42 PM
XJTexas
Agreed!
XJTexas is offline
post #7 of 10 Old 05-10-2014, 01:43 PM
XJTexas
Agreed!
XJTexas is offline
post #8 of 10 Old 05-11-2014, 08:57 AM
rjbruzan
Also when was the last oil change. Is it reasonably fresh? As it gets older the pressure will drop as the oil gets old.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #9 of 10 Old 05-12-2014, 04:32 PM Thread Starter
austinkoceja
Thanks guys I'm not to worried about it now and .I changed the oil the day before
post #10 of 10 Old 05-12-2014, 07:28 PM
rjbruzan
Maybe you banged the sending unit. Its right above the oil filter.
rjbruzan is offline
