1998 2wd 2.5 swap to 4.0 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 1998 2wd 2.5 swap to 4.0
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-28-2014, 12:49 PM   #1
bigboi407
i have been reading around that the 4.0 and 2.5 wiring harnesses are very similar which would require less wiring problems, But idk if this is true or not..
I have a 1998 Dodge dakota reg cab 2.5 and AX15 2wd, i would like to drop in a straight 6 4.0 into my chassis because the 2.5 isnt enough to pull a fully loaded truck to my liking
Wouldnt i need to get another 2wd 4.0 transmission due to the HP difference?
bigboi407 is offline   Reply With Quote Quick reply to this message
Unread 08-29-2014, 09:11 AM   #2
StanF
No, the AX15 you have would be fine with the 4.0L.
But you'll need a new bell housing to mate to the 4.0l. 1994 and later with external slave.
StanF is offline   Reply With Quote Quick reply to this message
