1995 Jeep Wrangler 4Wheel drive question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 1995 Jeep Wrangler 4Wheel drive question
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 03-02-2008, 07:46 AM   #1
Cordova_1
I have a 95' Wrangler and for some reason the 4wheel drive is not engaging. The vacum harness and vacum motor are new....? I pulled the two vacum ends off of the vacum motor and only one side was getting vacum. The other side never got vacum even when I went to 4H or 4L...? Does anyone know what could be the cause of this? Please help....
Also, when re-installing the vacum motor, which side of the axle should the ring be on? (if I asked that correctly..?) I lined it up to the vacum motor's fork position...
Cordova_1 is offline   Reply With Quote
Unread 02-06-2012, 01:31 PM   #2
nickcee47
http://www.jeepforum.com/forum/f95/s...fails-1320576/
I talked about the same problems read the thread might help. my shifter is messed up so idk if this stuff is the problem
nickcee47 is offline   Reply With Quote
