1991 wrangler smells like gas leak - JeepForum.com
post #1 of 4 Old 09-26-2012, 05:21 PM Thread Starter
geminiJeeper
I have no apparent leak whatsoever but after running the jeep there is quite the fuel smell. (Only after its been running). Anyone know what I'm talking about or have any advice?!?!?!? Help me
geminiJeeper is offline
post #2 of 4 Old 09-26-2012, 10:39 PM
YJinOC
My YJ used to do that. Fuel tank seal (pump/sending unit gasket) for me. Auto zone had
YJinOC is offline
post #3 of 4 Old 09-27-2012, 08:40 AM
jon87yj
check the tank seal,return lines, evap lines, fill hoses, evap canister.
jon87yj is offline
post #4 of 4 Old 09-27-2012, 10:38 AM
jnicewan
Like mentioned above you need to look over everything related to fuel or fuel vapor, crankcase/pcv lines too. The couple areas that can be overlooked are the hoses to the charcoal canister, the injectors, fuel rail and pcv/ccv system
I have seen injector o-rings leak, injector bodies leak, pcv hoses disconnected or rotten, along with evap hoses (charcoal canister) Leaks around the injector are too common and usually not very big plus they can evaporate quickly, either check with the engine running or check cold after turning the key to on/run and check for dampness or residue.
jnicewan is offline
