1990 wrangler ignition problems - JeepForum.com
post #1 of 3 Old 03-12-2010, 10:41 AM Thread Starter
jeepinLen
My 1990 Jeep Wrangler 6 cylinder loses ignition at completely random times. Some times it will start immediately, some times it may be an hour or so before it will start. The engine turns over but there is no fire to the spark plugs. I've replaced the coil and distributor but the problem was not affected. Any suggestions? HELP, I wanna ride!
jeepinLen is offline
post #2 of 3 Old 03-12-2010, 07:22 PM
mojeep
had the same prob on my 89 ended up being the motorcraft (ford) ignition box
mojeep is offline
post #3 of 3 Old 03-12-2010, 09:26 PM Thread Starter
jeepinLen
Yep, thought the same. Removed it and had it tested and it checks out ok.
1990 wrangler has seen better days johnt7558 Engines & Drivetrain 0 10-20-2009 08:23 AM
problems with ignition jkl9964 Engines & Drivetrain 2 10-12-2009 11:30 AM
ignition switch problems Budlight Audio, CB & Ham Radios, GPS, & Electrical 3 02-25-2009 06:03 AM
1990 wrangler headlights and tail light troubles ImpactFabWorks Audio, CB & Ham Radios, GPS, & Electrical 0 01-30-2009 01:00 PM
1990 jeep Wrangler Ax-15 Can i install TJ Transfer case? yamasled03 Engines & Drivetrain 1 03-17-2006 04:50 AM
