1990 cherokee with run up idle problems - JeepForum.com
post #1 of 4 Old 12-24-2011, 04:58 PM Thread Starter
dcwyle
I have a 1990 jeep I6 4.0 manual 4 x 4. Starts fine however the idle slowly starts running up until it is out of control. Have replaced all the sensors but still have the problem. Any ideas ? Thanks
dcwyle is offline
post #2 of 4 Old 12-24-2011, 08:59 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Replaced all what sensors? If you replaced the TPS, did you adjust it?
cruiser54 is offline
post #3 of 4 Old 12-25-2011, 07:25 PM Thread Starter
dcwyle
Yes I adjusted it within limits stated in repair guide. Lets see I have replaced the TPS, idle air , oxygen sensor, egr valve, crank position sensor. Thats about it that I can remember right now.
dcwyle is offline
post #4 of 4 Old 12-25-2011, 07:37 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Try these instructions for the TPS:
RENIX TPS ADJUSTMENT
Before attempting to adjust your TPS be sure the throttle body has been recently cleaned.
It's especially important that the edges of the throttle butterfly are free of any carbon build-up.
IMPORTANT NOTE: Using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector
of the TPS . The letters are embossed on the connector itself.
Touch the black lead of your meter to the negative battery post.
If you see more than 1 ohm of resistance some modifications to the sensor ground harness will be
necessary. The harness repair must be performed before proceeding.
I can provide an instruction sheet for that if needed.
MANUAL TRANSMISSION:
RENIX manual transmission equipped XJs have a three-wire TPS mounted on the throttle body.
This manual transmission vehicle TPS provides data input to the ECU. The manual transmission
TPS has three wires in the connector and they're clearly embossed with the letters A,B, and C.
Wire "A" is positive.
Wire "B" is ground.
Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors..
Note the voltage reading--this is your REFERENCE voltage.
Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your
OUTPUT voltage.
Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For
example: 4.82 volts X .17=.82 volts. Adjust the TPS until you have achieved this percentage. If
you can't achieve the correct output voltage replace the TPS and start over.
AUTOMATIC TRANSMISSION:
RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three-
wire connector, same as the manual transmission vehicles have, and it is tested the same as the
manual transmission equipped vehicles--FOR ENGINE MANAGEMENT RELATED ISSUES.
However, the automatic TPS also has a square four-wire connector clearly embossed with the letters
A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module.
Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your
REFERENCE voltage.
Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT
voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage.
For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage.
If you can't, replace the TPS and start over.
So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and
the other side feeds the TCU. If you have TRANSMISSION issues check the four-wire
connector side of the TPS. If you have ENGINE issues check the three-wire connector side of
the TPS.
For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is
stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced.
Revised 11-28-2001
1990 Cherokee idle issues FOURohXJ Engines & Drivetrain 4 10-13-2011 05:42 PM
1990 jeep cherokee hammergod Engines & Drivetrain 0 07-06-2011 07:04 AM
1990 cherokee ignition issue tyguyty Audio, CB & Ham Radios, GPS, & Electrical 1 08-12-2010 01:49 PM
1990 wrangler ignition problems jeepinLen Engines & Drivetrain 2 03-12-2010 09:26 PM
1990 cherokee 4.0 hesitation at start swells Engines & Drivetrain 4 01-01-2009 01:40 PM
