Quantcast 1990 2.5L wont start... well, will start but not stay running. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 1990 2.5L wont start... well, will start but not stay running.
Old 11-18-2009, 12:31 PM   #1
Shandley
1990 MJ Comanche
Greetings to all!
I hope you can help me out.
I have a 1990 2.5L Jeep Comanche and she wont start anymore. lol
Here it is: In 2001, I blew the engine on a long road trip. I have since rebuilt the bottom end. I had some troubles getting it going at first but once I cranked the engine, it fired up. I didn't drive it much at all for about 6 years but I would start it up. Now, its been about a year since I've last started it and it wont start.... Well, it will start but it will die right away.
The fuel is new. I am bringing in a fuel filter just in case but it was replaced when I rebuilt the motor.
The plugs are fine (except the excess gas on them, which I've now cleaned off), the wires are fine. The cap and rotor are new.
I have been told that it might be a CPS I don't have a crank position sensor on this one (1990).
I have been told that I should check the MAP sensor but wouldnt that just cause rough running or over fuel consumption?
I am at a loss. Please help!
Thanks,
Shandley
Shandley is offline   Reply With Quote
Old 11-22-2009, 02:55 AM   #2
CherokeeGirl
1990 XJ Cherokee
gasoline over time becomes stale and can leave deposits. I would check the fuel pump and injectors
CherokeeGirl is offline   Reply With Quote
Old 11-22-2009, 02:37 PM   #3
Shandley
1990 MJ Comanche
Thanks for the reply. I turned out to be a top o-ring for the fuel injector. Fuel was spewing out the top and causing a miiighty rich mixture. lol
The o-ring was next to impossible to get. I eventually found one at a local auto parts store for $0.25. The dealership wanted $22 and it was 2 weeks away.
Now all I have to work on is my power issues. When I give 'er, it has a massive hesitation. I thought timing at first but that's just fine. Any ideas?
Thanks,
Shandley
Glock Forum
