1989 jeep che lifter taping need advise - JeepForum.com
post #1 of 4 Old 02-08-2009, 08:46 PM Thread Starter
dodgeram1982
1989 FSJ Cherokee
hi i have an 1989 jeep 4.L has an valve tap at idle up to 1500 rpm that i can hear . i changed the oil no change so i took the valve cover of checked the push rods 9 dont move 2 barly 1 has some play im not sure if it is the valve spring or the lifter makes the nose very clear when i let of the gas . has good power just hte noise i statred it with the cover off all looks ok up down up down . do u have to remove the head to replace the lifter. any advice would be great thanks
dodgeram1982 is offline
post #2 of 4 Old 02-08-2009, 09:43 PM
xyimmyx
1988 XJ Cherokee
the valves arent adjustable on these engines. you probably have carbon acumulating on the valvetrain. Try some engine cleaner treatments. there s a product GUMOUT that I used in the past on a slant six motor with this same issue. You pour it in your engine before changing the oil and let it idle for 5 min and then drain it and fill it like usual, it clean some of the crap out. Theres also fuel system cleans, that will help clean your intake valve, as they tend to build up carbon too. I like the TECHTRON brand by chevron. We use it at work almost exclusivly. It is meant to be pour into the tank when you fill up but we jsut pour it threw the throttle body little by little liek you woul dwith other intake cleaners. Smoke liek a MOFO though so dont do it in the garage.
xyimmyx is offline
post #3 of 4 Old 02-09-2009, 06:59 PM Thread Starter
dodgeram1982
1989 FSJ Cherokee
i tride that additives still the tap tap tap
post #4 of 4 Old 02-11-2009, 08:16 PM
wrightjeep
yank the head
building a newer jeep, one part at a time. LOL!
wrightjeep is offline
Drilling, Taping and Machining with Coconut Oil Unlimited04 Fabrication Shop 30 04-27-2017 11:15 AM
1989 Jeep Cherokee - Head-Unit -> Amplifier wire run path? Danorexic Audio, CB & Ham Radios, GPS, & Electrical 4 03-22-2009 03:32 PM
What would be a good engine to put in my 1989 Jeep Comanche comancheman89 Engines & Drivetrain 8 02-01-2009 02:21 AM
1989 jeep wrangler rear end rosengrant826 Engines & Drivetrain 2 09-24-2008 02:53 PM
taping question Tuffy General Jeep & Off-Road Equipment 5 06-22-2008 08:52 PM
