1989 4.o only overheats on highway....please help me :-( - JeepForum.com
post #1 of 10 Old 06-11-2002, 11:25 PM Thread Starter
Erbo
ok here is the deal i have a 1989 jeep cherokee limited with a 4.0 and one day i was driving it on the highway and it overheated to the point where it burst one of my radiator hoses. (yes it was an old hose) After fixing that i noticed my jeep would run in the red area after a bout 30 minutes on the highway but would cool down if i got off the highway and drove on ordinary town roads. i replaced the thermestat hoping this would fix the problem but it still runs hot and only runs hot on the highway.........please help with any sugestions!!
thanx,
chris
89 JEEP CHEROKEE WITH A 3 INCH LIFT AND 31 ALLTERAINS
Erbo is offline
post #2 of 10 Old 06-12-2002, 03:18 AM
cj7traildriver
Is the water pump working, do you have a mechanical fan or a electric one. If mechanical is it a clutch fan check clutch fan if working properly may not spin clutches slip after awhile. If electric do they turn on. Do you have anything covering your radiator like fabric or cardboard? I would say thermostat but you have switched that. How hot does it get what size T-stat did you put in? How old is your coolant, do you have dexcool mixed with anything else coolants dont mix well. May need a coolant flush.Have you ever added radiator fix a leak, you know the stuff you add to plug a hole in the coolant it also plugs other stuff dont recomend useing it. These are some things to look into.
Jeep what else matters.
cj7traildriver is offline
post #3 of 10 Old 06-12-2002, 10:47 AM
4wheeler4CJ
4wheeler4CJ's Avatar
LOL, basically what HE said, LOL <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
post #4 of 10 Old 06-12-2002, 12:08 PM Thread Starter
Erbo
ok nothing is blocking the radiator and the fan is working fine so i guess i will try flushing out the radiator.......wish me luck..
Erbo is offline
post #5 of 10 Old 06-16-2002, 08:31 AM
jeepcherokeev6
i dont know what your actual problem is, but:
after screwing up the radiator and fan, i decided to get the rad re-cored to a 3-row. i also added an electric fan i had laying around.
anyway, driving down the highway...at 90 MPH, when it goes that fast...at 3-4000 rpm...with a/c on, the needle is just barely above the blue zone on the temp gauge.
just a cooling suggestion
and yes, i still have factory thermostat
Dan, San Bernardino, California
'86 XJ, 2.8 V6 5 spd, 3" lift
"It may be a piece of sh**, but its MY piece of sh**!" -Me
jeepcherokeev6 is offline
post #6 of 10 Old 06-17-2002, 02:43 PM
JIM79CJ7
JIM79CJ7's Avatar
ERBO,
If you Have a Clutch type fan this is where problem will be .Your fan will work fine around town because it pulls enough air at low speeds but get on the highway and it does not let enough air pass through radiator .I suggest replacing fan clutch. I have seen this alot of times .
Good Luck ,
JIM
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #7 of 10 Old 06-17-2002, 03:42 PM
BillR
BillR's Avatar
I had the same problem on an '87 XJ, and it was a BEAR to find the cause...
I found that the metal coolant lines under the pressurized overflow bottle were blocked, and not allowing coolant to flow properly. I probably could've cleaned out the lines, but I replaced the radiator with one from a '91 that had a regular cap. I yanked out the pressure bottle, rerouted the heater lines, and put a standard overflow bottle in. Problem solved!!
Again, you can try cleaning out the metal lines, and it may work for awhile...
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #8 of 10 Old 07-16-2002, 07:09 PM
BigBobG
overheats
Friend of mine just had the same problem with his Passat.
Spent a long time looking for a solution only to discover that partial blockage in his exhaust system.
It's worth a look!
BigBobG is offline
post #9 of 10 Old 07-20-2002, 09:12 AM
rebelr91YJ
I had the same exact thing happen with my '91 Wrangler. Replaced the fan clutch,radiator and thermastat......still happened. I pulled the water pump and found the impeller was corroded so bad it was almost totally gone. Replaced the pump and all has been good since (about 40,000 miles)
'91 YJ 2" PA BL,1-3/4" shackle lift, 31" M/T's,AR wheels,F/R tow hooks,CB w/4'K40 antenna,Full Metal Jacket bedliner....more to come
rebelr91YJ is offline
post #10 of 10 Old 07-21-2002, 09:54 PM
microtek
I had the same problem with a 90 Cherokee Sport. Before you spend any more money, purge the cooling system of all air.
microtek is offline
1989 4.0L no power /no oil pressure jplifee Engines & Drivetrain 7 01-18-2010 07:22 PM
1989 4.0 engine Jdaniel343 Engines & Drivetrain 0 01-17-2010 07:40 PM
My 1989 4 banger just blew up Thunder Head Engines & Drivetrain 11 12-06-2009 04:25 PM
wire harness for 1989 whyjay Audio, CB & Ham Radios, GPS, & Electrical 1 10-16-2009 01:20 PM
1989 YJ 2.5L Bellhousing snidave02 Engines & Drivetrain 4 11-19-2007 09:56 PM
