1989 4.0L no power /no oil pressure - JeepForum.com
post #1 of 8 Old 01-15-2010, 12:30 AM Thread Starter
jplifee
i have a 1989 MJ with some major engine problems and i bought it knowing it needed a new engine, but i couldnt let this one go
its been sitting for 6 months
i drove her home with falling oil pressure only a few miles but it had really bad had power and acceleration so i parked it got some restore and dumped it in
after this it seem to get worst and, has no power now
i wondering if anyone has an idea whats wrong and what are my options to fix it?
my guess is that the oil pump started to fail for some reason and slowly starved the engine of oil,
previous owner says it was a bearing some place but he had no idea, and his mechanic quoted 1500 for a rebuild and he just wasnt up for it.
sounds pricey i found a shop that will swap in a reman with warranty for 1600
but i just wanna make double sure this engine is dead before i shell out any money
or explore the possibility's on fixing the current motor?
symptoms are
misfiring sounding/ choppy running
no power!
NO oil pressure!
i only went around 7 miles straight home like this and now she is sitting
im thinking about dropping the pan tomorrow to inspect the oil pump/ see if any metal parts are mashed up
any advise is greatly appreciated
Thanks JP!
1989 Comanche Long bed PROJECT!!
1999 Grand Cherokee Limited 4.7
184,000 and counting
jplifee is offline
post #2 of 8 Old 01-15-2010, 08:09 AM
4.7stroker
Sounds like it is dead to me. You could pull the head and the oil pan and inspect the carnage.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 8 Old 01-17-2010, 10:32 AM
herbiehind
sounds like it ate the cam;bent some valves; and called it a day .depending on the warranty; that 1600 sounds like a good price . they doing the rebuild? or they buying a long block?
herbiehind is offline
post #4 of 8 Old 01-17-2010, 10:34 AM
herbiehind
just reread ; they 're buying long block . i'd go that route; unless you can get one yourself and do the work .
post #5 of 8 Old 01-17-2010, 06:35 PM Thread Starter
jplifee
Dwayne
what do you think a stroker would cost? and do you know any good builders?
i might go that way, if the engine is coming out might as well do something cool with it.
jplifee is offline
post #6 of 8 Old 01-18-2010, 07:17 PM
herbiehind
man i was trollin' on here a while back and alot of stuff on strokers . there are a few routes to go . post a question on strokers and sit back . the opinions and knowledge will flow . lol . love this site . there's a company that does the 4.6 i think with warranty . some day .
post #7 of 8 Old 01-18-2010, 07:22 PM
herbiehind
hey check it out!! scroll down a ways from this thread . there's a thread about trucking dealing with a 4.6l stroker !!! go figure .
post #8 of 8 Old 01-18-2010, 07:22 PM
4.7stroker
Or you can go here a forum dedicated to the stroker.
Jeep Strokers • Stroker Basics
Dwayne
[url]
[url]
What is the correct street tire pressure and off-road pressure? JeepinYahoo Tires & Wheels 84 04-11-2013 05:52 PM
1989 4.0 engine Jdaniel343 Engines & Drivetrain 0 01-17-2010 07:40 PM
My 1989 4 banger just blew up Thunder Head Engines & Drivetrain 11 12-06-2009 04:25 PM
High Power Steering Pressure dakarpsi Engines & Drivetrain 1 09-19-2009 11:27 AM
1989 YJ 2.5L Bellhousing snidave02 Engines & Drivetrain 4 11-19-2007 09:56 PM
