1987 jeep wrangler 4.2 no spark - JeepForum.com
post #1 of 13 Old 07-04-2012, 04:49 PM Thread Starter
dsims1987
Have replaced ignition control module the ignition coil spark plugs ignition switch pick up coil rotor and distributor cap still nothing anyone have any ideas?
dsims1987 is offline
post #2 of 13 Old 07-04-2012, 09:21 PM
kilo1974
May be a beating a dead horse here but,, have you pulled off dizzy cap and cranked engine over to see if your rotor is rotating,,, you may have a broken pinion gear on your distributor,,, just a thought..
kilo1974 is offline
post #3 of 13 Old 07-04-2012, 09:30 PM Thread Starter
dsims1987
Yep I did its still spinning
post #4 of 13 Old 07-04-2012, 09:41 PM
kilo1974
And you have no blown fuses or anything??,, I had an issue similar to that with an early 90 's full size suburban,, turned out that my ecumenical fuse was blown,, thus no spark, but plenty of crank,, go figure..
kilo1974 is offline
post #5 of 13 Old 07-04-2012, 09:52 PM Thread Starter
dsims1987
I was thinking the only thing left to change is the computer but someone told me I could change the ignition system out and bypass the computer have you ever heard of that ? And yes checked the fuses.
post #6 of 13 Old 07-04-2012, 10:04 PM
kilo1974
Bypassing the computer is something that us with 85 to 95 wranglers and cjs do to put your jeep back to a pre 82 or so state of mind,,,it's referred to as the nutter bypass,,, very effective solution to the computer controlled ignitions and carburetors of the early (experimental) 90 's,,, look up nutter bypass in the forum home page,,, and look for an article written by mike romaine,,, very helpfull if you are starting from the beginning ..hope the info gets you going in the right direction,, happy jeepin
kilo1974 is offline
post #7 of 13 Old 07-04-2012, 10:08 PM Thread Starter
dsims1987
Thanks for the info will do
post #8 of 13 Old 07-04-2012, 10:14 PM
kilo1974
The only thing tricky about the write up on the bypass is the color on the wiring,, there is a minor discrepency between cj and wrangler as far as the colors,,, if you get into it hit me up and I will do my best to help,,,, I did the bypass on my 90 wrangler 4.2 some time ago and had nothing but good results in the end..
kilo1974 is offline
post #9 of 13 Old 07-05-2012, 11:15 AM Thread Starter
dsims1987
Tank you so much it's running now but none of my gauges work is that part of bypassing the computer or seperate problem
post #10 of 13 Old 07-05-2012, 11:35 AM
kilo1974
That would be something different,, be sure to wrap all connections well and check all connections..you may have unplugged something accidentally.
kilo1974 is offline
post #11 of 13 Old 07-05-2012, 04:37 PM Thread Starter
dsims1987
20 amp fuse and they are working thanks for all your help
post #12 of 13 Old 07-05-2012, 06:18 PM
kilo1974
Awesome to hear your guage issue was a fuse, also glad to hear that you got the jeep going again,, happy jeepin friend
kilo1974 is offline
post #13 of 13 Old 07-05-2012, 09:15 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do a GM HEI distributor conversion and don't look back.
cruiser54 is offline
