1978 J10 with a 343 - JeepForum.com
post #1 of 32 Old 12-23-2012, 08:27 AM Thread Starter
1978levisj10
1978 J-Series Truck
1978 J10 with a 343
I just purchased a 78 J10 Levis edition. decoded the vin and it should be a 401. crawled under the truck and checked casting on the block and found it to say 343. further research on the 343 it was not a production motor offered after 1969 so I could possibly have a 290hp V8 in this vs the 215 hp 410. Is this a good score.
1978levisj10 is offline
post #2 of 32 Old 12-24-2012, 07:05 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
1976 was the last year for the 401 in the Jeeps. How did you come up with a 401 for a 1978?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 32 Old 12-24-2012, 07:46 PM Thread Starter
1978levisj10
1978 J-Series Truck
7th digit in the 78 vin is a z which makes it a 401. But it has a 1968 amc 343 4v engine
post #4 of 32 Old 12-24-2012, 08:10 PM Thread Starter
1978levisj10
1978 J-Series Truck
Vin J8A25NZ
J= Jeep
8= 1978
A= Toledo Ohio Lhd auto
25= J10 truck 119 wheel base
N= GVW 6200
Z= V8 401 4v
post #5 of 32 Old 12-25-2012, 12:25 PM
rjbruzan
343 is a good motor. The 401 is also. Iill bet the 343 is alot easier on fuel.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #6 of 32 Old 12-25-2012, 02:51 PM Thread Starter
1978levisj10
1978 J-Series Truck
Not sure about that had to trailer it home. Replacing the battery cables plus and wires to see if it will run. It turns over
post #7 of 32 Old 12-31-2012, 05:12 PM Thread Starter
1978levisj10
1978 J-Series Truck
Well replaced the battery cables, plugs, wires, cap, rotor, coil, fuel filter and and fuel pump to and electric now need to purge the gas tank and add fresh fuel
post #8 of 32 Old 12-31-2012, 05:14 PM
deliriousnomad
and then?
*** edited numerous times for your viewing pleasure ;)
deliriousnomad is offline
post #9 of 32 Old 12-31-2012, 05:25 PM Thread Starter
1978levisj10
1978 J-Series Truck
Draining the tank in the morning then the fresh gas. It turns over and fires but won't catch yet
post #10 of 32 Old 12-31-2012, 05:26 PM Thread Starter
1978levisj10
1978 J-Series Truck
Turns over fine just need to get fresh gas backfiring like a champ with the old gas
post #11 of 32 Old 01-01-2013, 02:04 PM Thread Starter
1978levisj10
1978 J-Series Truck
Well fresh gas and still backfires but not running at a lost. Will run a compression test next weekend
post #12 of 32 Old 01-04-2013, 09:52 PM Thread Starter
1978levisj10
1978 J-Series Truck
Determined tonight that the timing is way out due to distributor not at the right angle. All the pics I have seen show the vacuum advance pointing towards power steering pump and the one on this truck is straight towards the radiator.
post #13 of 32 Old 01-05-2013, 10:48 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Better check the distributor drive gear while you have it out
jeepdaddy2000 is offline
post #14 of 32 Old 01-11-2013, 09:57 AM Thread Starter
1978levisj10
1978 J-Series Truck
Can anyone check the wiring to their coil on their v8 need to check to see if I have the right wires hooked to the positive side of the ignition coil
post #15 of 32 Old 01-12-2013, 10:11 AM Thread Starter
1978levisj10
1978 J-Series Truck
Please will someone check there ignition coil hook up on their fsj v8 and help me out with the color of the wires to the coil
