1970 cj5 wont charge. - JeepForum.com
post #1 of 2 Old 10-23-2011, 04:07 PM Thread Starter
dagrizz
I had the battery tested and it's in good shape. I put a new starter and cylinoid in. It only has one wire coming off it though. It has a newer altanator. I had the altanator tested and it would not put out a reading. I was told that even if it was bad it would still put out a small reading. Any suggestions? I'm at a loss. Thanks a lot.
dagrizz is offline
post #2 of 2 Old 10-23-2011, 04:50 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I'm assuming you have the stock Motorola alternator (might want to fill out your profile).
If you had the alternator checked and it isn't putting out any voltage, then my guess is it is bad. If you can get it working and the system won't charge, the next step is to have the voltage regulator checked.
After that, you can check to see if you have power to the alternator warning light (if the light bulb is bad, the charging system won't work) and then on to the alternator itself.
In the end, an upgrade to a GM internally regulated alternator can be done with a minimum of effort.
jeepdaddy2000 is offline
