1955 CJ5 Fuel Problem - JeepForum.com
post #1 of 6 Old 06-18-2014, 04:44 PM Thread Starter
DanHaga
1955 CJ5
Hey guys, I could use some help. My Jeep 55 CJ5 (4-cyl) recently stopped getting fuel so I ordered a new fuel pump for it. I installed the new pump and I just cannot get it to start. I have a transparent fuel filter and I watch it remain dry as I just crank and crank.
I have blown air thru the lines from the pump in both directions so no clogs.
I have tried putting some gas in the carb and itll start for a second but just die soon after.
Any suggestions?
DanHaga is offline
post #2 of 6 Old 06-18-2014, 09:46 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
May have a pinhole leak in the fuel line, causing it to pull air
collapsed fuel line
Bad pump
First check to insure you have fuel flowing out of the tank and through the line. Remove the inlet side (sucking) and pressurize the tank. If fuel doesn't flow out of the hose, then you have a plugged line or the sock in the tank is full of crud.
With the inlet side (sucking) still off, crank the engine. You should get vacuum at the nipple. If not, then you have a valve issue, pump arm not engaged, or diaphragm is bad.
If you have vacuum, then hook up the inlet line, take the outlet line off, and crank it again. If you get fuel out of the pump, then the line to the carb is blocked, fuel filter plugged, or the carb float is stuck shut.
If it has a glass bowl, insure it is sealed
I know it sounds stupid, but don't get the vacuum booster (if equipped) for the wipers confused with the fuel pump.
jeepdaddy2000 is offline
post #3 of 6 Old 06-20-2014, 08:58 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Any suggestions?
Transparent fuel filter? Are you talking about the sediment bowl just before the carb? The inline fuel filter is probably attached to the frame just outside of the fuel tank.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 6 Old 06-24-2014, 05:54 PM
carnuck
1984 J-Series Truck
Rust hole in the line, or the pick up in the tank or someone drained the last drop of fuel. I use a siphon pump to draw gas through the new pump. Oh! The lobe could be wiped out! (or a Chinese made pump is DOA)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #5 of 6 Old 06-26-2014, 10:45 AM
strvger01
1966 CJ5
doesn't the '55 have the bottom mounted fuel line? just crack it open and make sure fuel is getting out of the tank. then, while you're under there, you can check for leaks in the line itself. next, i'd double check your new fuel pump. i just went through 3 of them on a vehicle of mine. the first two were bad.
no offense, but your new fuel filter was put on correctly? there is usually an arrow showing flow direction. this sometimes gets overlooked.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #6 of 6 Old 06-26-2014, 10:49 AM Thread Starter
DanHaga
1955 CJ5
Thanks for the help guys. Got a new pump and managed to get it started. But now I have new issues to ask you about.
I have a 1955 CJ5 with the 4-134 engine. It idles ok but when I give it any kinda gas is hesitates and bogs down. Sometimes also pops and blows a mist of gas outta the carb.
Some quick details. I have done a 12v conversion. Everything electrical is new.
I use this distributor:
I use this carb:
This all really started when I installed the new distributor. The shaft is keyed so it can only be installed one way so pretty sure I didnt screw that up. The timing is set correctly. I even tried putting the old distributor back in and it the problem remained. Points look good, dwell is good...
I followed the instructions perfectly for setting up the solex carb a even tried swapping the factory carb back in and that didnt help.
Tried fuel pump spacer.
Fresh tank of gas.
Plugs look fine, wires are new.
Compression test shows good numbers in all cylinders.
Any one have any ideas or suggestions? I am stumped.
I took some video of a vacuum gauge while idle, slowly applying throttle and tapping the throttle. Can you guys have a look and tell me what you think?
https://www.youtube.com/watch?v=j18k7fpKH7A
Here is another video just of the engine while playing with throttle.
https://www.youtube.com/watch?v=8SlEBoL2nHo
DanHaga is offline
