? 10w40 for a higher milage motor? - JeepForum.com
post #1 of 2 Old 10-29-2012, 08:18 AM Thread Starter
psychovinnie
i have a 99 xj with the i6. its got 171450 miles. a friends dad suggested that when i get my oil changed at 171500, i should switch from 10w30 to 10w40. said the thicker oil will help preserve my engine; and that he had put 10w40 in his 70 bronco for that reason. wats you thoughts? should i switch or no?
psychovinnie is offline
post #2 of 2 Old 10-29-2012, 09:57 AM
90DesertTanYJ
If your experiencing lower oil pressures the 10W40 will help with that. If your not having any issues I wouldnt worry about it. You could use a "hi mileage" oil if you want but the syntho has a tendency to creep out in spots you didnt have leaks before.
90DesertTanYJ is offline
