'07 XK 4.7L Stalling, Hesitation, misfire. Help - JeepForum.com
post #1 of 9 Old 04-21-2017, 10:21 AM Thread Starter
BigPete
2007 XK Commander
I'm having a problem with my '07 4.7L limited. 148k miles. Coughing, sputtering, wild idle and at times it dies and stop lights. After the check engine light comes and i use the remote start, it'll rarely stay running longer than 5-10 secs. After it dies that first time the remote start wont work anymore, it just honks the horn once instead of twice. This mostly happens in and just after being in traffic and it is guarantied to happen if I run the a/c.
stuff I've done to try and fix the issue:
re-flashed the ECM
new OEM spark plugs from Chrysler/Dodge/Jeep
replaced vacuum line on back of intake (had a leak)
replaced the ambient air sensor (like above)(mine looked good, but replaced anyway)
example:
On a trip from San Diego up the mountians to Big Bear (about 3hrs drive time) last month we hit traffic for a few miles and without turning on the a/c it started having idle issues. After we got clear of the stop and go, I could only ease into the throttle a little bit otherwise it'd couch and sputter hard until i let off the gas. I was able to get up to 65-70 mph, but trying accelerate to pass anybody was out of the question. When we got to the mountain's windy road and kept it under 47/50 mph i could accelerate somewhat hard until it hit 50, then it would sputter hard again.
With 148k I understand that there will be things that are ready to be fixed. Do you think it'd be worth it to just replace the Crank position sensor, or should I roll the dice and take it back to the dealer and have them charge me a Boat load and not fix the problem again. I've taken it to them 4 times now. 1st and 2nd time they found nothing wrong with it. 3rd time i had them Flash the ECM...still no change, and the 4th time they fixed the vacuum leak, trany line leak and water pump(these needed to be fixed, but...). All this and it still acts the same. The only thing i do now that is different from then is that i don't run the a/c, but it still happens from time to time. Luckily not as bad and not for very long.
thanks for reading through this.
Pete
BigPete is offline
post #2 of 9 Old 04-21-2017, 10:08 PM
OldTimer51
Similar symptoms once with my 1973 Datsun 240Z. Replace the fuel filter.
OldTimer51 is offline
post #3 of 9 Old 04-24-2017, 09:50 AM Thread Starter
BigPete
2007 XK Commander
That is something I was thinking about, but wouldn't that be somewhat consistent weather or not I was running the a/c?
I swapped out the Crank Position Sensor this week end and so far it didn't help. I'm hopping that it needs time to settle. My wife drove it home and i had her put the a/c on and it ran like crap, but once she turned off the a/c it started to smooth out and not act a fool. On another forum, a guy sugested checking voltage, engine off, engine running(a/c off), and engine running a/c clutch engaged. He was saying that new cars start running bad if the voltage is < ~13 volts. I haven't checked this yet, but it is now on my list of things to do.
BigPete is offline
post #4 of 9 Old 04-27-2017, 09:16 AM Thread Starter
BigPete
2007 XK Commander
Update.
I replaced the crank position sensor that i got from the dealer this last weekend and was able to drive in med to heavy traffic with the a/c on to give it a real good test. I drove about 20-30 min to get my hair cut and it drove there fine, but when I came out to leave it started running like crap. I turned the a/c off and it smoothed out a bit, but not back to normal.
i did some research to find the fuel filter and apparently there isn't a separate filter. There are two "filters" on this jeep, one is the sock on the intake of the fuel pump and the second is a screen immediately after the sock... no inline filter on the frame or anything >.<
BigPete is offline
post #5 of 9 Old 05-03-2017, 05:16 PM Thread Starter
BigPete
2007 XK Commander
BUMP, anybody?
BigPete is offline
post #6 of 9 Old 06-05-2017, 10:10 AM Thread Starter
BigPete
2007 XK Commander
Update:
Hi y'all. I'm wondering if anybody might have anymore input on these problems. I just had my battery tested and it came up "bad", so i replaced it. I drove it for a week, back and forth to work with the a/c on and i thought that the whole problem with the multi-cylinder misfire was resolved, wrong. This weekend i took my wife and family up to Temecula for wine tasting and the issue started up again. it even died a couple of times ant the stop lights.
any help would be useful
thanks again for y'alls time.
BigPete is offline
post #7 of 9 Old 06-13-2017, 09:41 AM Thread Starter
BigPete
2007 XK Commander
Update:
Review of what has been done:
1) New battery
2) All connections checked for wear and damage
3) New crank position sensor
4) New Throttle position sensor
5) New Cold idle valve
6) ECN reflashed to current programing
7) New lock and tumbler
new as of 6/12/17:
1) new plugs
2) tested each of the coils.
I'm not to sure if i'm getting good readings or not. If one of you could let me know if i did this right, it'd be a big help.
I tested each coil's primary and secondary windings with a ome meter to measure resistances of each. One source says the primary should be .6-.9 ohms & secondary should be 6-9k ohms. the second source (autozone) primary .55-1.1 ohms 6-15k.
here are the measurements it took:
P / S
1)1.0/8.08
2)1.1/8.20
3)1.0/8.16
4)1.0/8.00
5)1.1/7.50
6)1.1/7.95
7)1.0/7.80
8).9-1.0/7.96
and pictures of the plugs I took out after, about 1 year:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
BigPete is offline
post #8 of 9 Old 06-14-2017, 11:17 AM Thread Starter
BigPete
2007 XK Commander
Update:
Last fix attempt didn't help...
I was reading in another forum that some problems with cracked or crappy trans filters can cause air bubbles to get into the trans valve body and cause slippage. thus have the trans stick and have the idle go crazy and sometimes lock up completely and kill the engine. what do y'all think?
any and all speculation is a help and welcome.
thanks
BigPete is offline
post #9 of 9 Old 06-21-2017, 09:17 AM Thread Starter
BigPete
2007 XK Commander
Update for those who might check this out.
I Bought a OBD II bluetooth reader and ran a diagnostic. I have a P0300 code, multicylinder misfire.
Here is a PDF of the diagnostic report:
File Type: pdf '07 commander Diagnostic report 6-20-17.pdf (252.2 KB, 0 views)
BigPete is offline
