06 TJ Rubicon 42RLE or PCM PROBLEM? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 06 TJ Rubicon 42RLE or PCM PROBLEM?
Building a Bumper?Ruffstuff Axle Simple Swap Kit!~Artec JK 1 TON SWAP~
Unread 10-19-2012, 09:36 PM   #1
PurposeBuilt
I just bought this 06 TJ (used to own a 00 TJ) and have read and read and read some more about the dreaded "hard shifts" and tranny issues. Also read about replacing or re-soldering the PCM...I'm about to spend $350 on o2 sensor and temp sensor on tranny (labor included) I've pulled the negative battery cable a handful of times to reset "memory" only to have problem return days later. Should i hold off on the sensors or should i spend my money on the PCM? Any help, opinion or perspective is greatly appreciated!
PurposeBuilt is offline   Reply With Quote
Unread 10-20-2012, 12:05 PM   #2
rjaargo
What code are you getting???? I have an 06 with the same trans. Mine was rebuilt just weeks ago because of a over temp code. However what caused the trans to over heat was the torque converter. I myself thought it was a PCM problem and it wasn't. Also the valve body on mine was replaced 4 times the temp sensor is part of the valve body.
rjaargo is offline   Reply With Quote
Unread 10-20-2012, 12:20 PM   #3
rjaargo
Also I forgot to tell you I also had O2 codes before rebuild. Since rebuild NO O2 codes.
Unread 10-20-2012, 05:43 PM   #4
PurposeBuilt
P0714 intermittent temp sensor (Trans)
P0418 cat warm up (o2)
Wow thanks for the feedback! How much did your tc rebuild cost?
Unread 10-20-2012, 05:46 PM   #5
PurposeBuilt
Actually what did the new tc cost you m
Unread 10-20-2012, 05:58 PM   #6
rjaargo
I spent about $1900 to rebuild the trans and $1300 for the PCM replacement
Unread 10-20-2012, 06:11 PM   #7
PurposeBuilt
Holy wow! But you say the PCM wasn't necessary?...
Unread 10-20-2012, 06:19 PM   #8
PurposeBuilt
I can't receive personal messages yet, not enough posts? Don't know?
Unread 10-20-2012, 06:20 PM   #9
brockj
i had a 2003 tj and was having pcm trouble. i got a rebuilt one off ebay for about $300. you send them your vin# and mileage. they program it so all you have to do is plug it in and go, and its a lifetime warranty. i ran the rebuilt one for about 10,000 to 15,000 before i sold it and never had any trouble with it. just an option
brockj is offline   Reply With Quote
Unread 10-20-2012, 06:28 PM   #10
rjaargo
No the PCM didn't fix the problem
Unread 10-20-2012, 06:29 PM   #11
PurposeBuilt
Brockj i was reading your posts and i bookmarked them and wrote down the company that sells those pcms, i will definitely go that route too, if needed.
Unread 10-20-2012, 06:31 PM   #12
PurposeBuilt
Do either of you know how too rule out one or the other? I'm actually a mechanic at a golf course, but not an electrical engineer? Haha
Unread 10-20-2012, 06:34 PM   #13
rjaargo
I am a mechanic also but I took mine to the dealer and had the diagnose it that way if they are wrong they can fix it. You can also try and go to google and type in the code along with year and make of the vehicle. Helped me a little before taking it to the dealer.
Unread 10-20-2012, 06:34 PM   #14
PurposeBuilt
Thank you both for your help...I'm torn at what route to go
Unread 10-20-2012, 06:36 PM   #15
rjaargo
When driving it does it go into limp mode???
